I got the truck when I was only 14. My grandma gave it to me. She was completely stock truck, with only a leveling kit on 35s and a sct tuner. Being from North Carolina it was a very clean truck.
Hope you guys enjoy the thread!
Chrome strips come off and duplicolor liner on.
Plus the 08 mirrors, which are awesome!! Then the bushwacker fender flares. I ended up not liking them and selling. The rubber weather strip would rub the paint.
So she looks good but what about performance.
I have installed
6637 kit from riff raff
Wicked Wheel
CCv reroute kit from riff raff
Riff raff ic boots
Riff raff boost fooler
Riff raff HPX
Ts 6 position chip
Aih delete with riff raff tap for boost line
Foil delete
Riff raff reinforcement intake plenums
4 inch turbo back to the stack'd rack
Fuel bowl rebuild. Drain valve was leaking. The low sulfur diesel fuel eats the two orings. I did a complete fuel bowl rebuild with upgraded orings from diesel orings.com
Thanks man!
I can't remeber which brand it is. The last time I changed the filter, the old filter was attached to the cap, so I had to rplace the hole thing. This is what autozone had, the filter is attached to it.
Well I checked my glow plugs the other day and all gave me a good reading except for number six. So I did some investigating and took off the valve cover. I did a continuity test through the wire and found my problem. I ended up making new connections, soldering them together then put a heat shrink connector around it. Fixed the problem!
Related Threads
Ford Powerstroke Diesel Forum
5.4M posts
265.8K members
Since 2005
