'01 Platinum Edition Project - Ford Powerstroke Diesel Forum
Powerstroke.org Builds & Projects Post your builds & projects here
post #1 of 5 Old 03-07-2014, 01:16 PM Thread Starter
Hey folks,
I'm trying to upgrade/restore my 2001 Platinum Edition to its former glory. It's not in bad shape (pics to come) but has some wear on it.
I have list of future wants but more immediate needs. I wanted to tap into Powerstroke.org, folks that helped keep my beast running in the past. Any help and direction is much appreciated in advance.
MODS: I put a hypertech chip, set to Stage 2, I have Banks Cold Air Intake system, Bellows Up-pipes, EBV delete, new pedestal, DieselSite Coolant filter, Evans waterless coolant. Replace all ball joints (MOOG) and outer seals/dust cover, new Hubs, brakes.
So you know where I'm coming from. I purchased her used in '05 as retirement gift (yes to myself, always wanted one). The transmission blew that year, complete rebuild, then she died again and Ford put a IDM, (I think thats right acronym) in it. She runs okay but is slowly losing MPG and making some rattling noises in the front end and it feels like the 4x4 is engaged. And she eats water pumps for breakfast.
IMMEDIATE PROBLEMS:
1. The ole girl has trouble starting below 40* plugged in she does fine. Not a normal problem with Texas heat but something is wrong, any suggestion?
2. She has an oil leak (on top) I can't pinpoint, I thought it was the pedestal but its not the pedestal this time. any thoughts on trouble shooting?
3. This will be my fourth water pump in three years, I buy Airtex but every 9 months or so I get the smell and another pump is gone. This one is after the Coolant filtration install. I'm baffled as to what could kill them so quickly????
4. When driving I get these rattling noises; to me they come from the front passenger side. The passenger side axle knuckle is very clunky and I have some gear oil showing. When I turn sharp it feels like the 4x4 is engaged is this normal at 300K miles? I did replace the sway-bar links. What could be rattling so much? ***I can't stand strange noises***http://www.powerstroke.org/forum/ima...LyT9B5AN1z.gif
As stated, I appreciate any help as I thoroughly go through the ole girl and make her run well and shine again...plus I need to put some new rings on her fingers (wheels and tires) Pics and updates to come.
Ronney is offline
post #2 of 5 Old 03-07-2014, 08:21 PM
heisman01's Avatar
Quoted: 52 Post(s)
are the mods on the list want to do's or already done? If not done, get a 6 position chip 6637 air filter and an exhaust if you want it.
Having trouble below 40 can be as simple as a gpr or switching oils for the colder months. I did a western gpr mod and run 10w30 in the winter and my truck starts the first time every time at -10. Read the cold start sticks and see if you can pin point your issue.
Are you installing the pumps or is a shop? Did you flush your coolant system prior to the new pump? I got mine from diesel site and its at least made it 9 months with no issues. Are you using distilled water (had to ask) or ecl coolant?
swap everything out to moog and get warn premium hubs, I have that set up and grease it every oil change almost 20k on it and zero problems.
DD- 11 6.7 scsb: sct4 gearhead tunes, 4" dpb axle dump exhaust, 2.5 level, fox shocks, no limit egr delete, no limit stage 2 intake, STT PRO 295/65r20, black fuel couplers
sold- 00 7.3 modded to the end.
heisman01 is online now
post #3 of 5 Old 03-08-2014, 03:25 PM Thread Starter
heisman01, Thanks for the reply,
The mods are already done. As far as the hubs, already changed them with Timken hubs. I want to keep the vacuum system unless there is any compelling reason I shouldn't.
For the cold, I'm running AMSOIL 15-40 year-round. The water pumps I installed. They are all leaking from the weep hole nothing leaking around the gaskets. I'm looking at their water pump with filter attached right now. Pretty clean set up. I use Evans waterless coolant and already have a filter system on her.
Ronney is offline
post #4 of 5 Old 03-08-2014, 04:19 PM
heisman01's Avatar
Quoted: 52 Post(s)
I got my water pump coolant filter and therm all in one shot from diesel site, you might as well try them next and see what there warranty is.
post #5 of 5 Old 03-10-2014, 09:27 AM Thread Starter
waterpump
I'm going to get my next water pump from DeiselSite.
Do you know what might cause all that noise I'm having in the front end and why the 4x4 would feel like its engaged?
Ronney is offline
