what should my next play be for 2002 7.3 - Ford Powerstroke Diesel Forum
Powerstroke.org Builds & Projects Post your builds & projects here
 1Likes
post #1 of 29 Old 12-18-2013, 04:33 PM Thread Starter
jakethesnake1990's Avatar
I have a 2002 f250 7.3, 8 inch lift, 38 size tires, has the basic upgrades like violant intake and silver exhaust and tony wildman chip. Im wondering what my next play would be, I was thinking about injectors and or turbo or both , would I also need head studs done. The guy I bought it from said it has 4.56 gears or 4.88 gears( he said he was pretty sure 4.56) but idk because my early 99 f250 had a lot more torque and throttle response it seemed off the line so im curious if my 2002 does actually have the gears. the previous owner also said this 2002 f250 has a upgraded HPOP. so my question is what should I do next?
tomricciuti likes this.
jakethesnake1990 is offline
post #2 of 29 Old 12-18-2013, 04:41 PM
Quoted: 3 Post(s)
Guages.. And if your thinking turbo or injectors, a lot more involved than just those. Turbo there are some drop in options, but injectors depending upon how much bigger your planning on going fuel system (reg return, pump, filter mods) first, then injectors. You probably have a pmr engine though. Also Bigger fuel and gonna need a built trans.. Really need to figure out what the plan is for the truck.
2000 DRW CC 7.3
Exterior: 08 Exterior Clone, 22.5's
Engine Mods: GTP38R WW2, 5 inch exhaust,T500, 6637, TW tunes,DI Up pipes, 6.7 fuel pump fuel system.
Trans Mods: 6.0 trans cooler, JW Valve body,Billet triple disc converter.
Sound Mods: 7" flip out tv, 3-way speakers all around, 12" sub, 500 watt amp.
Misc:dieselsite coolant filter, max ac assist, BRV, IHD,gauges, CCV
Next up power rear window
campbellflage is offline
post #3 of 29 Old 12-18-2013, 04:44 PM Thread Starter
I've got guages I just need to get the egt
2001 F250 7.3
8 inch lift on 37s
6 Pos ts tony wildman tunes
Pillar gauges
4.56 gears
jasper rear
Stage 1 injectors
Silverline exhaust
Violant intake
Viper keyless start
post #4 of 29 Old 12-18-2013, 05:52 PM Thread Starter
I just want to make my truck have more power and a little more get up and go. It runs like a 11 second 0-60 right now. I dont want to do anything that will start causing problems down the road either. If i were to get a turbo should I also get a fuel system? what turbo and fuel systems do you recommend.
post #5 of 29 Old 12-19-2013, 04:36 AM
Quoted: 3 Post(s)
Depending on what tunes you have, getting a turbo will probably not give you any seat of the pants results, just lower egt's.
2000 DRW CC 7.3
post #6 of 29 Old 12-19-2013, 03:33 PM Thread Starter
I just have a tony wildman chip. If not a fuel system and turbo then what should i do next ?
2001 F250 7.3
8 inch lift on 37s
Pillar gauges
4.56 gears
jasper rear
Stage 1 injectors
Silverline exhaust
Violant intake
Viper keyless start
post #7 of 29 Old 12-19-2013, 04:43 PM
Quoted: 3 Post(s)
what are you looking to spend money wise?
2000 DRW CC 7.3
post #8 of 29 Old 12-19-2013, 04:56 PM Thread Starter
Couple grand maybe.
2001 F250 7.3
8 inch lift on 37s
Pillar gauges
4.56 gears
jasper rear
Stage 1 injectors
Silverline exhaust
Violant intake
Viper keyless start
post #9 of 29 Old 12-19-2013, 05:14 PM
Quoted: 3 Post(s)
could do stage 1's, ww2, and maybe reg return for that. Be closer to 400whp and "safe-ish" with pmrs and a stock trans.
2000 DRW CC 7.3
post #10 of 29 Old 12-19-2013, 05:17 PM Thread Starter
Sorry what is a ww2
2001 F250 7.3
8 inch lift on 37s
Pillar gauges
4.56 gears
jasper rear
Stage 1 injectors
Silverline exhaust
Violant intake
Viper keyless start
