99 F-250 Superduty Axles - Ford Powerstroke Diesel Forum
Powerstroke.org Builds & Projects Post your builds & projects here
post #1 of 3 Old 12-09-2013, 02:16 PM Thread Starter
My 1999 F-250 Front D50 needs an upgrade.
There is a guy in my area selling an 1986 F-350 Front D60 and rear D70.
Will the 86 front axle bolt right in my truck?
Can i use my ring and pinion from the D50? (his is a 3.55 mine is 3.73)
Is the D60 from 86 a "unit bearing"?
I plan on building a front D60 with the 3.73 gears.
Any suggestions on parts and or gearing?
would it be worth using his D70 rear or should i keep the 10.5" rear that my truck already has? Will the D70 rear bolt up to my truck?
What should i pay for these axles? He wants $1400 for both...
nsktwo is offline
post #2 of 3 Old 12-10-2013, 11:04 AM
wayyyy over priced for them, and also the bolt pattern is different
Pullnpray is offline
post #3 of 3 Old 12-10-2013, 11:08 AM
kraker829's Avatar
You can get a used 50 for your truck pretty cheap at the yard.
kraker829 is offline
Tags
axle , axle build , d50 , d60 , gears
