Well here she is picked it up for $3500. 2001 F350 CCSB Lariat 7.3 4X4 Auto trans with mild lift and awful looking 20" wheels. Has unknown engine issue. I was told engine is locked up, but a 15/16 socket on the vibration damper bolt says otherwise. Also told has dead cylinder from starting fluid. Not sure whats wrong. Its been sitting for quite a while. Batteries are junk. I went into this truck on worst care scenario of pulling the engine and rebuilding which is going to happen im sure. But first lets see if it will fire up. Before it got dark last night threw the jumper box on it real quick only to hear the starter grinding away. Both bolts where way loose. Pulled it out to see if its still good, seems fine. Gonna throw it back in and tighten everything up and see what happens! Lots lots more to come!
PLANS:
Performance engine rebuild
ZF6 swap!
Ditch all the chrome!
Front end needs work too
PLANS:
ZF6 swap!
