Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > Towing, Hauling & Diesel Competition > Powerstroke Off Roading
Powerstroke Off Roading Pics, stories, vehicle recovery
Old 10-19-2006, 08:21 PM
Logan Logan is offline
The Fat Mod
Lift or No Lift, that is the question
If you plan on doing any sled pulls, is it better to have a small lift or have stock ride hight?
Old 10-19-2006, 11:55 PM
99Smokin73Stroker 99Smokin73Stroker is offline
Breaking balls since 1981
Send a message via AIM to 99Smokin73Stroker Send a message via Yahoo to 99Smokin73Stroker
I don't know which is really better, but as long as you have a way to keep the axle(s) from wrapping like a son-b it shouldn't matter too terribly much. I would rather pull in a truck on 35's or slightly smaller.....
Old 10-19-2006, 11:57 PM
Marty Marty is offline
International Threat
Send a message via AIM to Marty
I've seen HUGE lifts do fine, with lots of mods... and stock trucks that do almost as good. I think it's all about traction, weight and power. If you can pull those off then you're in for a ride.
Like I told ya though, Mech will be able to give you very IN-DEPTH info on this... I've never pulled, I sit on the sidelines and watch.
Old 10-20-2006, 10:21 AM
I've also seen huge lifts do well, but they probably could have done a little better and gotten more of their hp/tq to the ground. It is in traction, weight and power as well as the track itself.
Old 10-20-2006, 10:44 AM
The Fat Mod
Because at some point, I want to go with a 4" lift. Not too much but something that would help clear a little bigger tire and something that would look good too. I am sure alot of the lifts out there are not made for the kind of weight or stress put on the system when pulling. But, I don't know much about and don't really know what I am talking about
Old 10-20-2006, 11:09 AM
Patrick Patrick is offline
The more lift you have the more leverage the bounce gets (axle wrap) but if you use some good ladder bars or traction bars that keep the axle from wrapping you should be just fine. Tall sidewalls will give you a bounce as well. On our 1000 hp 79 Ford we run a 4 link rear suspension with airbags (only 8psi) that me and Larry made. We also use 35" Truxus STS's very good tire. We dont get any bounce, but we also hang about 3k pounds off the front bumper lol.
Old 10-20-2006, 11:11 AM
The Fat Mod
Pat, sounds like a mean rig. Thanks for the info. Would you go with a 2" leveling kit to fit 35s or 4" with traction bars?
Old 10-20-2006, 12:29 PM
On yours I would just lift it. It would look a whole lot better.
Old 11-06-2006, 11:22 PM
House22 House22 is offline
Send a message via AIM to House22
a small lift is fine, i am taking mine all off though i want my front low to the ground
Old 11-08-2006, 12:10 AM
The Fat Mod
Thanks for the tip House. Any other tips you might have would be great.
