lost boost - Ford Powerstroke Diesel Forum
Powerstroke Forum Polls Vote here!
post #1 of 4 Old 10-02-2013, 10:38 PM Thread Starter
lost boost
I own a 05 f350 with the 6.0 and when I am towing my 5th wheel on the interstate and going up hill at anywhere from 55 to 75 mph or more when the factory boost gage reaches 30 lbs it will drop to 5lbs . It doesn't seem to lose much power. The engine does seem to make a different sound. It will stay at 5lbs for only a few seconds then it will go back up . I have had it checked , but there are no codes. The truck has 117000 miles on it. Any one have any answers .
THANKS!!!
rogers is offline
post #2 of 4 Old 10-03-2013, 04:53 AM
Bluedemon6.0's Avatar
Send a message via Skype™ to Bluedemon6.0
If you are concerned with the gauge reading improperly install a manual boost gauge. I think the factory boost gauge gets it's reading from the map sensor but an aftermarket gauge would get its reading from the intake manifold. Just a thought you can try to clean the hose from the map sensor to intake manifold.
-Steven
New!! 2015 Mustang ecoboost!!
Sold!!
formally owned:04 6L PSD CCSB
Studs
Egr delete
S&b intake
New dashboss with fuel pressure and egt
Sct Looney by Vivian and Tonywildman xtreme early lock up now
php 140x
63.5/88mm 06 turbo with a pmax billet WW2
PHP Atlas 80
My baby-
87 jeep wrangler
350 and 700r4 built by mad dawg transmission
Dyno @ 200hp and 400ftlb at 3100 rpm
On 33s
Bluedemon6.0 is offline
post #3 of 4 Old 10-03-2013, 05:56 AM
kinnisoj's Avatar
Quoted: 2 Post(s)
Are you running original boots? I wonder if they are getting tired and flexin under the pressure. Im not even sure if thats possible without completely blowing off.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #4 of 4 Old 10-03-2013, 08:33 PM Thread Starter
Not sure about the gauge and everything is original except for the 4'' exhaust .
rogers is offline
