- HOME
- FORUMS
- GARAGE
- ARTICLES
- CHAT
- CLASSIFIEDS
- VIDEOS
- TECH
- STORE
| Powerstroke Forum Polls Vote here! |
| View Poll Results: What Chip/Programmer are you using in your 7.3L Powerstroke? | |||
| Superchips Microtuner |
97 | 24.13% |
| Edge Juice/Att Monitor |
41 | 10.20% |
| Edge Evolution |
57 | 14.18% |
| Bullydog Power Pup |
11 | 2.74% |
| Bullydog Dyno Dominator |
1 | 0.25% |
| Bullydog 4Bank Chip |
16 | 3.98% |
| Diablosport Predator |
19 | 4.73% |
| Hypertech Programmer |
27 | 6.72% |
| Banks Six Gun |
31 | 7.71% |
| TS Performance 4Bank Chip |
102 | 25.37% |
| Voters: 402. You may not vote on this poll | |||
| Sponsored Links |
Hey Mike, Sounds like your makeing a valiant try at it. The mistake I know I have made is believeing everybodys advertisments and figureing if I add them up I should get about 100mpg. The other mistake was changeing to many things at once. I'm a little excessive compulsive they say. I know that what works well on one engine might not work so good on another. Point, I changed the exhaust on a gas truck a few years ago. I thought it would be awesome. Not so, I almost lost half the fuel mileage. Problem, the cam timeing was wrong for a 0 backpreassure system. I would like to see a realworld test between the 4" and 5" exhaust. I like the idea of insulateing the intake more. If I can handle the power loss, I'm running this week with the ecm backed down to stock, I will evaluate each device. There isn't much that I havn't touched so backing up might take awhile.
I have been looking at a water injection system and thinking that might help? and I am toying with the idea if electric cooling fans. I am in need of some expert advice from some body in the know, When it comes to gas I understand it to the point that I even believe I understand how Earnest Pouge got 200 miles per gallon back in 1928 (THE FAMOUS 200 MPG CARB) He discovered that liquid gasoline won't burn. But I lack the understanding as to pushing up the mpg on diesel. By the way I forgot to tell you I have a big head waste gate control also. I have talked to the Banks engeneers two diesel shops and even put it on a mechanics web page to see if anybody had any good ideas. Banks told me it had to be fuel because I took care of the air??? maybe??? one diesel shop told me to let them know if I figure it out because they would like to know also. Another shop told me I needed to change my injectors from a double fire to a single fire injector?? which I have been told by someone else "won't work with my computor" and a ford mechanic told me to take it back to stock to find the problem. The problem in trying to figure it out is no one puts down what in real time happens so you can see what is going wrong, Mercedes got 2000 miles per gallon on a test car - I think that 18 or 20 miles per towing isn't to much to ask. If and when I understand and figure it out I will let everyone know MIKE OB P.S. I just got a brain storm / I am going to put a adjustable resistor in the back pressure sensor line so I can tell it what I like and I will do the same to the fuel pressure sensor. I have read where higher fuel pressure will improve your fuel mileage and I have read in the Ford manual to ck for high fuel pressure if your haveing poor fuel mileage. I believe the right hand is not suer if the left hand is even there.
Well Mike, I tried the electric fans on my 460 truck a few years ago. It was nice on the coast but I took it on the road to eastern wa. state in 107 degree weather. I found out real quick that I needed way more fan than I had. I know the pricipals of the heat activated fans our trucks have but it could be better. My big trucks have an air clutch fan that is on with out air. The same could be done on our trucks with an electric clutch that would be locked in without power. Even thow our thermo fans aren't locked totally, they do draw some power. Thats funny you should mention the ICP control. I was just at another PSD site and the thread I was reading was about the ICP controllers. This guy said he wouldn't put one of those chaep %#@^ things on his rig. I have one on each of my psd trucks. They are worth every penny. You can stack these on top of any other chip or programmer. Like I was saying about starting over to test fuel mileage. I'm going to go without any electronic mod's first then, the ICP low & high and onto the programmer and see where I went wrong. Keep strok'n it. Talk with you soon. Bill
Second air intake
I just added a second air intake that goes into the air box lid, I used a abs 3 1/3 pipe, got it hot with a heat gun and mashed it flat, like a 1 1/2 inch tall - then I cut a hole in the top of the ari cleaner and tried to glue it in with abs glue (WARNING ABS WON'T STICK TO THE AIR BOX) I found some plastic two tube mix and glued it in. Then I connected it with a hose to infront of the battery with a second filter. Mike OB
Air flow
When I get a minuet I am going to post some pictures and material used to do it. It was less then 50 dollars and more then doubled my air flow. Mike OB
| Sponsored Links |
