Go Back   Ford Powerstroke Diesel Forum > General Topics > Powerstroke Forum Polls
Powerstroke Forum Polls Vote here!
Old 08-07-2006, 09:33 PM
TYMOL TYMOL is offline
Mpg
I am intrested in a 05 or 06 Powerstroke with crew cab, 4 x 4, and single wheel axel. Currently I drive a Duramax. MPG is an important factor. Could you all with simular rigs post your MPG. Please let me know empty and towing MPG - with what your towing-. Thank you
Old 08-07-2006, 09:45 PM
99Smokin73Stroker 99Smokin73Stroker is offline
Send a message via AIM to 99Smokin73Stroker Send a message via Yahoo to 99Smokin73Stroker
I think 6.0's and 6.6's are pretty comparable in mpg's from what i've read. I would say unless you want the better looking and larger truck, keep the d-max.
Old 08-07-2006, 09:52 PM
super_stroke super_stroke is offline
Power Strokeaholic
WHAT???? your fired smoke. lol. they are pretty close.
Old 08-07-2006, 10:53 PM
Marty Marty is online now
International Threat
To give you some real #'s I can do that, however I have the "less efficent" 7.3 which I generally average 17mpg mostly city/secondary roads.
Remember the Ford weighs a bit more then both chevy and dodge trucks. This gives them a disadvantage as far as mpg goes, however they get similar reviews in the mpg area. 16-20 empty depending upon driving habits/locations and 9-14 towing once again depending upon driving habits/locations and weights. I think the lowest I've seen recorded was 8mpg grossing 22,200lbs in a 2005 F350 dually.
Old 08-30-2006, 07:59 PM
Mike OB Mike OB is offline
Mpg
Hello: I belong to our local Elks and we have a club called the RV Romers. There is about every kind of rig you can find, I would say stock that the gm built gets a bit better then Ford or Dodge, however - if your willing to put some money into your rig, you can improve your mpg and power. If you get the 4x4 mod your gear ratio is going to change what you get, it will lower your mpg, but will out pull the 2by. But like you have been told, if you have big feet your mpg will suck. Good luck I hope this helps. Mike
Old 09-02-2006, 01:18 PM
Green Horn Green Horn is offline
I have an '01 F-350 with the 7.3 and I am averaging about 17mpg in the city and when I tow my 10,000 lb. toy hauler I average about 11mpg. Hope this helps.:beer3:
Old 09-02-2006, 02:41 PM
Clay Henry Clay Henry is offline
Sooner Powerstroker Mod
100 mpg on vegi!!
Old 09-02-2006, 05:17 PM
100 Mpg
Originally Posted by CHenry View Post
100 mpg on vegi!!
Do you get that kind of mileage sitting on the can?
Old 09-02-2006, 07:31 PM
WTF?
Old 09-02-2006, 07:38 PM
What, you don't believe I get hat kind of milage? actually i get better than that sometime.
Tomorrow, I'm loading up and driving to arkansas with the family....hang out in the hills and do some hikin and such. I will leave here in Olahoma, drive about 300 miles and i promise you i will not burn more than a quart or diesel fuel. Lets see, doesn't that work out to about 1,200 MPG of diesel? :
Yep, it does....al be damed!
:tease:
