| Powerstroke Forum Polls Vote here! |
6.0 L cylinder head replacement
Guys I have a question?
I might have bent a valve on one of my cylinder heads. The question I have is can I change only the bad cylinder head with head studs or do I have to change both.if I have to change both can you provide a reason besides labor. Also finding a goog source for heads makes me nervous in finding a good supplier? Can someone recommend a reputable company to me? Thanks for any advice Robert mcDonald 972 968 9234 |
Yes, you can change just one head-ford does it all the time. HOWEVER, doing the second one is VERY easy once you have it taken apart enough to get the first one off-we're talking an extra 2-3 hrs at the most, and will save you a lot on labor in the future. Not to mention installing studs on one side of the engine is just crazy.
Do both while you are there man!
You can't buy just half the studs either... All it will cost you is one more gasket and a few more hours of labor. Make sure you have the heads milled very slightly to ensure flatness and torque to ARP specs and not Ford's.
Sent from my ADR6325 using AutoGuide App |
