PTP Stage 1 & 2 Powermaxes - Ford Powerstroke Diesel Forum
Performance Truck Products Performance Truck Products
post #1 of 2 Old 10-18-2013, 10:31 AM Thread Starter
Eric@PTP's Avatar
Just letting you guys know we are working on some new set ups for the 6.0 crowd. We are currently testing two stages of Powermax turbos, the Stage 1 is a 66mm cast wheel and the Stage 2 is a 71mm available in cast or billet. We are going to be gathering before / after dyno test # 's as well as differences in EGT, Boost, Back Pressure and over all Driveability. These are not recommended for stock injector set ups obviously, but for the guys who have stepped up injectors and need more air than the standard box Powermax can provide and want to retain their VGT for quick spool up these may be the ticket.
Once we have some data to go over we can decide what changes need to be made if any before offering them on the site. Just wanted to give you guys a heads up on good things to come from PTP.
Here's a peak at the 71 below.
1-888-516-4644
GO NAVY
Eric@PTP is offline
post #2 of 2 Old 10-22-2013, 07:49 AM Thread Starter
Eric@PTP's Avatar
And they're on the site now.
http://performancetruckproducts.com/...rbo-04-07-6-0l
Thanks
1-888-516-4644
GO NAVY
Eric@PTP is offline
