Diamond Eye 5" exhaust - Ford Powerstroke Diesel Forum
Performance Truck Products Performance Truck Products
post #1 of 3 Old 03-16-2012, 08:58 PM Thread Starter
Quoted: 85 Post(s)
Feedback Score: 3 reviews
Which one of these kits would work better in my situation. The K5342A-RP or the K5350A-RP? I am looking for a kit from the turbo back without a muffler. I would like to be able to put the cat back in because I have to smog it every two years. Thanks.
2006 F250 8" inch Pro Comp, Top Gun Customz dual steering stabilizer, Bilstein 5125's, 4.30 gears Toyo MT 37's, Powermax, SCT X3 w/ Matt's 8k Tow tune, BPD 53 volt FICM, DC Power 185 alt, PMM coolant filter with Rotella ELC, Edge Insight CTS, MBRP 4", Line X'd bumpers, grille, and tonneau cover
villestrip is offline
post #2 of 3 Old 03-16-2012, 09:00 PM Thread Starter
Quoted: 85 Post(s)
It looks like the later kits has reducers to re enter the cat in as needed? Maybe I don't know.
post #3 of 3 Old 03-23-2012, 08:02 AM
Eric@PTP's Avatar
If you want to be able to swap the cat in and out I would do the K5342A-RP and a section of pipe to weld flanges on it so you can swap them out. Not sure where you live but there is really no smog test, they just rev it up to 1500 RPM's and look for smoke. There is no exhaust hydrocarbon test like there is for gassers. If you could run a clean tune and gut your cat you should have no issues passing the visual for the cat and the smoke.
1-888-516-4644
GO NAVY
Eric@PTP is offline
