| Performance Machine & Manufacturing |
EGR delete question
I have a question. I just purchased one of your EGR delete kits, the one with the up pipe. My question is, where is the coolant routed with this installed? my current egr cooler is bad. What are the benefits of this over something like the bulletproof delete?
The coolant goes straight back in the motor. The bulletproof is an upgraded EGR cooler but you will still be dependent upon the EGR valve not failing. In my opinion doing the delete is a better option but I think the bulletproof is a good piece if you want to keep an EGR cooler. Let me know if you have any further questions.
-Matt H Btw, did you buy direct or from one of our dealers? If through us could you provide the order number so I can see contact info? Thanks. Sent from my Autoguide iPhone app |
I got it new off another member off here. I guess my question is my egr cooler is plugged up. By adding this egr delete, do i get rid of the factory cooler? Also, what is the purpose of the uppipe? is this what replaces the factory cooler? lastly, do you have install instructions available for this online or pdf?
It completely gets rid of the EGR system including cooler, valve, and existing up-pipe with exhaust hole for the cooler. The up-pipe is the same thing except it does not have the exhaust hole in it. There should be instructions in the box with it. If not we can email you some. We don't place our instructions online for other reasons. Let me know if you need anything else.
-Matt H Sent from my Autoguide iPhone app |
awesome. I look forward to getting it installed when i get back from afghanistan
Did you receive this, I haven't heard back from you? Just wanted to make sure you aren't having any problems.
my girlfriend said she got. i'm held up here in afghanistan due to medical stuff. i'd still like a copy of the instruction manual if possible so i know what im getting myself into
Sorry to hear about the medical issues. Hope everything works out. I will also see why you never received these instructions. I thought I sent it that's why I was asking. Sorry bout that.
