6.0L PowerStroke Coolant Filtration Kit PRE-ORDER SPECIAL!! - Ford Powerstroke Diesel Forum
Performance Machine & Manufacturing
Old 11-04-2011, 02:35 PM
Performance Machine & MFG. is proud to introduce the First Coolant Filtration System to the Market that DOES NOT require any cutting or splicing to ANY of your OEM Heater Hoses.
IF ORDERED PRIOR TO 11/21/2011 YOUR PRICE IS $99.00, AFTER 11/21 PRICING GOES TO $124.95
With so many Coolant Filtration Systems on the Market with the same technology and design, Performance Machine & MFG decided that we would do something the competition hadn't thought of yet. With our system you do not have to do any modifications to your factory hoses, PERIOD! We supply you with a new radiator return line made of the same HIGH QUALITY Silicone Hose that is provided with the rest of our kit and it has the coolant filter line tied directly into it and is joined together using brass ferrules to eliminate the need for those ugly hose clamps. We also supply you with a short section of 3/4" Heater Hose so you don't have to modify your existing heater supply hose.
Kit Contents:
  • Performance Machine & MFG. Filter Base
  • Coolant Filter
  • Mounting Hardware
  • Return Hose Assembly w/ Ball Valves
  • Supply Hose Assembly w/ Ball Valves
  • 2 x 3/4" Hose Clamps
Pre-order here: Performance Machine & MFG. 6.0L Powerstroke Diesel Coolant Filtration System
Old 11-04-2011, 03:46 PM
Do you have any other pictures than the one on the website?
Old 11-04-2011, 03:50 PM
I can take some more tomorrow there is a unit on the truck I am driving. Its not a full production version but you can get the gist of it.
Old 11-04-2011, 04:40 PM
Curious about how you don't need to cut into factory lines, but very interested... Especially with that pricing.
Old 11-04-2011, 04:47 PM
say no to rolling coal
Tagging this one. Want to see more detailed pics. If it looks good I'll consider jumping on board.
Old 11-04-2011, 04:50 PM
What u talkin bout willis
Send a message via AIM to REDPOWERSMOKER Send a message via Yahoo to REDPOWERSMOKER
I'll pre order on Monday.
Old 11-04-2011, 08:19 PM
Look forward to the photos. Does the system have shut off valves? Makes changing the filter cleaner.
Old 11-04-2011, 08:40 PM
Very interested! Will this have any type of ball valves or shut-off valves for changing filer?
Thanks,
Bri
Old 11-04-2011, 08:53 PM
Feedback Score: 9 reviews
Very interested as well.
Old 11-04-2011, 09:00 PM
I'm definitely interested!
