anyone local to butler pa? - Ford Powerstroke Diesel Forum
Old 04-23-2009, 01:00 PM
im looking for someone local to butler that has the software to come over and check my truck out. and do the buzz test on the injectors. i cant drive it yet cause its not legal. i dont want to make it legal till it runs half decent.
ill throw out a couple bucks for the help. currently laid off so not much to throw out.
Old 04-23-2009, 07:16 PM
Send a message via AIM to harrys91rs
I'm located in zelienople and have Auto Enginuity. I don't know if it will work with a 95 7.3
Here's what it says for my scantool:
"NOTE: AutoEnginuity may not work properly on 1994 and some Early 1995 Powerstroke trucks unless the computer has been reflashed to the latest PCM code for that particular model truck. This is because some of the early PCM programming didn't properly support the OBDII standards."
Old 04-24-2009, 07:23 AM
ill call ford and see if i can take the pcm up and get reflashed for obd2 if possible and let you know thanks for the reply
production date on the door is 5-95 if that helps
