Deleted in PA - Ford Powerstroke Diesel Forum
post #1 of 5 Old 04-17-2014, 03:18 PM Thread Starter
Deleted in PA
Do you guys that run deleted get any grief on annual inspections? Don't want to be hassled by the inspection place for deleting.
lizardking is offline
post #2 of 5 Old 04-24-2014, 06:49 PM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
Depends, if you use a legal shop, then you most likely get failed. If you use a "lick and stick", then you pass.
Sent from AutoGuide.com App
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #3 of 5 Old 09-27-2014, 01:54 PM
jmeaby's Avatar
Quoted: 16 Post(s)
I know this is old but find a performance shop and they will not fail you
04 f250 cc sb.
Egr block off, 4 inch turbo back ss magnaflow exhaust, billet turbo wheel, 05 Harley headlights, S&B intake, XDP coolant filter, tuned with Sct by PHP, BDS Dual rear add a leaf, Firestone ride rite airbags, 2 12 inch kicker subs, infinity rear speakers, mb quart frontdoor speakers, mb quart amp, autopumpkin Android headunit, torque pro.
jmeaby is offline
post #4 of 5 Old 09-08-2015, 09:58 AM
Beastmode's Avatar
Quoted: 23 Post(s)
Im.confused here....with a 3/4 or 1 ton, you don't need emissions in pa
Beastmode is offline
post #5 of 5 Old 09-08-2015, 12:03 PM
Mikeski0890's Avatar
Quoted: 2 Post(s)
These look to be old posts so i am assuming the OP was able to get his answer. Emissions vary county to county in PA. But for the most part you are correct with 3/4 and 1 tons and even diesels for that matter not requiring annual emission inspections. Been deleted for years without a problem although the place that deleted mine does my inspections.
2007 F350 CCLB Lariat
4" Turbo Back Straight pipe exhaust
Barder Stage 1 Turbo
BPD Water Pump
BPD 53V FICM
EGR Delete
Blue Spring Upgrade
Coolant Filter
SCT w/ Gearhead,Innovative Tunes
Mikeski0890 is offline
