Dryer stopped drying. - Ford Powerstroke Diesel Forum
Old 05-05-2009, 07:16 PM
My room mate and my's dryer stopped doing what its only purpose is. It still will turn on, but doesnt make a lot of heat and takes literally hours to dry some socks. We checked out connections and the lint trap is free. To be honest I just dont know my way around a dryer very well.. Any help?
BTW its electric.
Old 05-05-2009, 07:19 PM
You check the duct on the outside? If there's a critter guard on it, it will clog and not allow any air flow. Other than that, I've never dove into a dryer.
Old 05-05-2009, 07:20 PM
Could be the heating element.
Old 05-05-2009, 07:21 PM
Chug-a-lug!!!
Heating element?
Old 05-05-2009, 07:22 PM
if it was in the house when u moved there its the landlords responsibility to fix it FYI
rdc rdc is offline
Grumpy Non-Socialist
BTW its electric.
I've kept old dryers going before instead of replacing them.
I've replaced heating elements and thermostats. Either can
cause the symptom you describe. You didn't say - is it electric
or gas? If electric, I'd suspect burned out heating element or
faulty thermostat switches.
Old 05-05-2009, 07:27 PM
The duct isnt clogged. that is what i did first. Ill check out the thermostat when i get a chance.
Old 05-05-2009, 07:28 PM
Illiana Chapter Director
It could have a thermal fuse bad also. But since it is running and just not drying weell, I would say heating element.
Chug-a-lug!!!
BTW its electric.
or gas?
Wake up Russ. Is it past your bedtime?
Old 05-05-2009, 07:30 PM
rdc rdc is offline
I looked right at it, and didn't see it!
