VIN Checks? - Ford Powerstroke Diesel Forum
Old 04-22-2009, 06:03 AM
VIN Checks?
Does anyone know where I could get a VIN check for a Truck?
I am looking for the installed options from the factory...
Any ideas?
Old 04-22-2009, 06:06 AM
Cynic
Just call the ford customer line. Give them the VIN, they will research it and send you a letter with build specs if you are the owner. I've done it with my past trucks.
Old 04-22-2009, 06:14 AM
So there is no way that someone can look it up?
I belong to a Duramax forum and there is a section that if you put in your VIN number then a couple of guys can look it up and tell you what all the factory options are on the truck... Ford doesn't do anything like that?
Old 04-22-2009, 08:06 AM
Try this site...
https://www.fleet.ford.com/maintenan...ls/default.asp
Old 04-22-2009, 08:11 AM
Cynic
Originally Posted by mrnecsteve View Post
That will not give you the build info.
