need some help - Ford Powerstroke Diesel Forum
Old 06-12-2008, 04:23 PM
need some help
i got and installed one of those security screen doors. heres the problem, the dogs pawed at the bottom of the door and poped the metal screen out of it... long story short i need to take it back for a refund. heres where i hit the problem. its installed with one way screws that you cant back out w a screw driver or pliers. without tearing down the trailer how do i remove those screws, is tehre a tool
Old 06-12-2008, 04:27 PM
Rob Rob is offline
if possible i would try to drill the heads off the screws. use a center punch and then drill just enough to get the heads to pop off.
Old 06-12-2008, 04:29 PM
Send a message via Yahoo to Drepka
use a dremel tool and cut you some slots for a flathead screwdriver to fit.
Old 06-12-2008, 08:26 PM
i am trying to do it with out damaging anything cause i have t return it but seein as its a piece of s**t i think thats the only way to get it off thanks i didnt think of using a dremmel. if i cut the heads off i think its gunna be a pain in the a** to get the bolts off but thanks guys
