a pint of gas to 10 gallons of diesel??? - Ford Powerstroke Diesel Forum
post #1 of 11 Old 06-11-2008, 02:51 PM Thread Starter
i heard if you put a pint of gas to 10 gallons of diesel it will keep it from gelling. and if that aint cool enough i also heard it will have a flame out the tail pipe. but yet some how doesnt hurt the engine. i want to try it but im too scared if any one has done this please say cause i just want to blow a flame
96 F250 powerstroke ext auto converted to 5 speed
, 4 inch lift, DP-tunes, 260k, its been swamped....
2011 f250 powerstroke, lariet, 900miles, all stock.....
red stroker is offline
post #2 of 11 Old 06-11-2008, 02:52 PM
Conservative and Proud
Banshee34's Avatar
Quoted: 8 Post(s)
I wouldn't do it.
2001 F350, Lariat SC LB 4X4 PSD
Quadzilla Commander
Zoodad with Stealth Screen
The Org. Staff reserves the right to move, modify, delete or merge posts at our discretion and without explanation.
Banshee34 is offline
post #3 of 11 Old 06-11-2008, 02:55 PM
scheidt27's Avatar
Originally Posted by Banshee34 View Post
I wouldn't do it.
I second that
2002 F250
Beans Diesel Performance Tunes
All Supporting Mods
scheidt27 is offline
post #4 of 11 Old 06-11-2008, 04:14 PM
rdc
Grumpy Non-Socialist
rdc's Avatar
Save your engine, and just light a fart!
Russ Cook
2008 F250 FX4 SC LB 4wd
visit
FabFours bumper/brushguard
Cook's Calibers, LLC
Warn winch
Freedom isn't free, but we make it cheaper!
My other diesel is an Olds
rdc is offline
post #5 of 11 Old 06-11-2008, 04:24 PM
Other vehicle is an F250
Hank's Avatar
From all I've read it ain't worth it. Don't do it. No gasoline or alcohol should be run thru a diesel.
Try farting in the tank...bet nobody has done that before!
2001 F250 Lariat Crewcab, Automatic, 4X4
(Late '99 Regular Cab Work Truck)
6.5" Pro Comp Lift ~ Traction Bars ~ Son-Built Sliders ~ 16" Pro Comp Xtreme Wheels with 35" BFG TA KM2s
4" Banks Exh.-Power Elbow ~ Wicked Wheel ~ DIY AMSOIL EaAU4090 Intake ~ PHP 6 Pos Chip ~ LowDown LED Upgrade
Stage 1 Injectors ~ HankDaddy
Mod. ~ BUILT TRANNY! 352 HP Shootin' for 375!
CAROLINA POWERSTROKE ASSOCIATION
Hank is offline
post #6 of 11 Old 06-11-2008, 04:40 PM
AJF
AJF's Avatar
DON"T DO IT!!!!!!!!!!
Say good bye to your injectors. Thats an old trucker trick and most of the them got lucky because for it to be successful and not hurt anything it has to be mixed together properly so it goes through mixed and not all at once, spend $9.00 on Howes or Power Service and do it right
AJ
2001 F-250 Lariet
Ext. Short Bed 4x4
DP Tuner, JWVB, Cowl Induction Hood, 6637 Intake,
4'' MBRP Exhaust, WW, Dfuser Fooler, Mac Inc. HPO-X, CCV mod, no EBPV, DI up pipes, Bilstein schocks, Ranchhand Bumper
AJF is offline
post #7 of 11 Old 06-11-2008, 06:37 PM
StarDriver's Avatar
That trick was used if there wasn't an diesel condiotioner available, the problem is, it doesn't remove moisture from the fuel that the conditioners do. Also, don't jsut run conditioners when it's cold, run some every now and then in the summer too.
I used to run conditioner every other fill in the generators in the summer that I operated for WCW Wrestling, and evert tank in the winter. ( You never want to have a fuel problem when you are doing live TV.)
2006 F-350 4X4 FX4 Tuscany Longhorn , Leer Custom bed cap, RECON lights, Upfitter switches, Whelen Lighting, Hi-Idle Mod.
Instructor at B.R.A.K.E.S (
28 years Commercial Driver.
StarDriver is offline
post #8 of 11 Old 06-11-2008, 07:01 PM
JimTJr's Avatar
Wait, before you do that,, ya gotta yell,,,,
"Here HOLD MY BEER, AND WATCH THIS"
JimTJr is offline
post #9 of 11 Old 06-11-2008, 07:22 PM
Rice Hunter
Diesel Freak's Avatar
sounds like a youtube video in the makes
Lloyd Vice Director of Virginia Strokers
2006 F350 6.0L SuperDuty Lariat 4x4
Magnaflow 4" S.S. Turbo Back, Lost Cat, 5" S.S. Tip
Custom Tuned SCT
6" Fabtech 4-Link Suspension- Dirt Logic Shocks-Dual steering Stabilizers
S.S. Brake Lines
Fumoto oil Drain Valve
Accufab Polished Elbow
BFG 37"x12.5"x18" Load "D" All Terrains
ARP Head Studs
EGR Delete
'03 Turbo Swap
Diesel Freak is offline
post #10 of 11 Old 06-12-2008, 04:00 AM
Rob
Rob's Avatar
Quoted: 2 Post(s)
dont do it unless you have a stash of money somewhere to cover a repair bill.....
Audentes Fortuna Juvat
(Fortune Favors The Bold)
move, modify, delete or merge threads/posts
at our discretion, without explanation
at any time.
Rob is offline
