Road trip next week. DFW to Milwaukee to Atlanta to DFW. - Ford Powerstroke Diesel Forum
Old 05-18-2008, 07:34 PM
Cynic
Ok.. I'm heading the Colgate WI (outside of Milwaukee) then to Acworth GA (outside of Atlanta) then back to DFW. I haven't decided on what route I'll be taking. If you live between these points, let me know.. maybe I can make a stop. I will probably be heading out next weekend and I'm not on real schedule.
I'll have internet access and my laptop up and running while on the highway, so I'll be somewhat in touch.
Also, I've been floggin' my old 7.3 pretty darn hard lately. I just got back from another dyno test session and have an interesting tap at idle. I'm pretty sure I over-revved the old beast and bent a push rod.. or 4. I'm failing a contrib test on 2 cylinders with known good injectors. I'm positive she'll be fine, but I may end up needing a hand.
Old 05-18-2008, 08:14 PM
Hey Dirk,just curious, is the tap at idle always there or does it come and go? Are you going back with stock or Chrommolly pushrods?
Old 05-18-2008, 08:18 PM
Cynic
More noticeable at idle, but you can hear it under load. It's not bad, just a stumble at idle now, highway running is smooth. Power is still well over 400hp/900lbs torque.
EDIT: I doubt I collapsed a spring or cracked a rocker.
Old 05-18-2008, 08:22 PM
Cynic
Forgot to say..
These are the push rods I'm looking at..
Diesel Innovations - Products
Old 05-18-2008, 08:26 PM
Ok, seems as your still making good power. Any smoke?be careful on your trip!!
Old 05-18-2008, 08:27 PM
Forgot to say..
I just put those in myself!!
Old 05-18-2008, 08:30 PM
Cynic
Tons of smoke, all black.. bit of white on hard pulls. Turbo can't keep up.
You likey? Good quality?
Old 05-18-2008, 08:35 PM
I had an idea when I first seen your post on the tapping hence asking the questions.
Yeah, DI has helped me a lot over the last couple of years. They were some of the best priced p-rods that I found which is a good thing. I think they are made from some good quality metal too.
Old 05-18-2008, 08:57 PM
say no to rolling coal
You'll be headed through my way, or somewhere near me on your way to Wisconsin, but unfortunately I'll be working next weekend... What are you heading up there for?
Old 05-18-2008, 09:33 PM
Cynic
Hauling stuff between family members houses. I lost my father, grandfather, and grandmother last year. Time to consolidate stuff between houses. My aunt lives in WI and my mom is in GA.
We are spread out everywhere.
