Any electricians in house. Ive got a question - Ford Powerstroke Diesel Forum
post #1 of 12 Old 06-09-2013, 07:15 AM Thread Starter
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
Need to run a 50 amp 240v range outlet. Run is gonna be 75ft. Is 6ga wire enough?
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #2 of 12 Old 06-09-2013, 07:22 AM
nohsp4u's Avatar
I am no electrician, let's get the out of the way. I have ran 220 for both my range and HVAC units. range was 50' and the HVAC was over 75' from the breakers. I simply ran romex to the breaker and used a 220 breaker.
I have had no issue with each. oh, when you attach the wire run, Cal code i guess is every 4' not every 4", Opps. My wire run is holding the house together. LOL
1997 F-350 XLT Lariat Crewcab long box 4x4. Oxford white with an ugly green. 133xxx miles. Hide away goose neck, banks turbo, exhaust, inner cooler, intake filter and gauges.
nohsp4u is offline
post #3 of 12 Old 06-09-2013, 05:06 PM
dieselcrawler's Avatar
Quoted: 23 Post(s)
I am licenced electrician... 6ga fine for 50amps even 60 amps up to 100'. Derating for distance doesn't come into play untill over 100'.
Sent from my SCH-I200 using AutoGuide.Com Free App
Greg
'99 E350 DRW Stahl 11' util box van, 7.3 PSD, stock. 138k SOLD
'00 F350 extcab, 9' utility bed, dually 228k
E'99 F250 extcab, S/Bed 211k. Sidelined due to motor issues.
'00 Excursion Limited, 7.3PSD 294k
'84 Chevy K-30, 6.2L TD, woods/trail beater. 141k
Semper Paratus
dieselcrawler is offline
post #4 of 12 Old 06-09-2013, 06:00 PM Thread Starter
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
That's what I figured about the de rating. It's been to long though since I've done it
Email:
Edge Insight CTS
Coolant filter
Dave is offline
post #5 of 12 Old 06-09-2013, 06:00 PM Thread Starter
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
Thanks man
Email:
Edge Insight CTS
Coolant filter
Dave is offline
post #6 of 12 Old 06-09-2013, 06:00 PM Thread Starter
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
Now if I could find someone local with smaller than 500ft rolls
Email:
Edge Insight CTS
Coolant filter
Dave is offline
post #7 of 12 Old 06-09-2013, 06:26 PM
gotta_gofast's Avatar
Quoted: 61 Post(s)
Lets work through it!
Using AWG 6 (assuming stranded THHN?) Code reference T 310.15(B)(16) tells us this wire is rated to 75 amps at 90*C, however since temperature ratings of termination lugs is unknown we must use "worst-case-scenario" column of 55 amps.
The formula to figure voltage drop is as follows...
VD= (2 x wire length x Amps x copper Ohms per 1000') / circular mils
2 x 75 x 50 x 12.9
26240
Punch in the numbers and you get roughly 3.7v drop. 240v-3.7=236.3v. Divide these numbers to come up with a percentage and we get... 1.6%
NEC requires us to maintain less than 3% voltage drop on branch circuit conductors. While guessing "is it good" will ballpark you, doing the math and knowing you are legal and within engineered limits is best. It covers your butt in case a building inspector hassles you or insurance ever blames "wiring".
'06 F250 FX4 6.0L typical bolt on
gotta_gofast is offline
post #8 of 12 Old 06-10-2013, 05:23 PM
Delivers Pizzas For Fun!
ol_Blue97's Avatar
u could also use #6 aluminum SER cable. (service entrance round) u can use #8 copper romex. any local supply house should be able to cut that for you. the #8 is much more expensive tho.
FRANK THE TANK
DIY INTAKE - HYDRA CHIP - MARTY'S E-FUEL - 250/200s
05 AXLE SWAP 3.73 - 2.5" PURE PERF. LIFT COILS - FOX SHOCKS
BTS TRANS - TYMAR DOWN PIPE - 4" EXHAUST
Waiting To Be Installed... gtx4294r, studs, springs, HPOP?
Originally Posted by STROKED_NY_023 View Post
You are so smart Frank, I dont care what Terry says.
ol_Blue97 is offline
post #9 of 12 Old 06-10-2013, 05:25 PM
Smoke Eater
Feedback Score: 5 reviews
Send a message via Yahoo to fdchief
will work just fine...
2007 F-250 Lariat Crew Cab
SPL LED Lightbar
20" Fuel Rims
35" Nitto MT's
SCT Livewire w/ Tony Wildman Tunes
PMM Full EGR Delete/ Coolant Kit
Hornblasters 540 Kit
LED Lightiing All Around
All kinds of other Goodies!
2005 Lariat Crew- GONE!
2011 Lariat Ultimate Crew- GONE!!!
Back in a 6.0hhhhh and lovin it!
fdchief is offline
post #10 of 12 Old 06-10-2013, 06:13 PM
Quoted: 23 Post(s)
Spend the money use the better product... get copper. I never used alum wire for my cc customers.
Greg
Semper Paratus
