Alarm + Turbo Monitor - Ford Powerstroke Diesel Forum
post #1 of 1 Old 04-08-2012, 05:14 AM Thread Starter
tinygiant's Avatar
I'm installing a Python 594 (equivalent to Viper 5904) into my wife's '04 X (6.0L). It has a turbo timer function, but I wanted to know if anyone knew (or could figure out) how to integrate the ISSPRO 4130 Turbo Temp Monitor. This monitor will check the actual turbo temp and shutdown when appropriate, vs. the simple timing function of the alarm system. Here's the basic laydown...
Connections:
1: Ignition Switch: Keeps engine running. (16AWG wire recommended)
2: Batt+: 12VDC A switch can be inserted in this lead to defeat the TTM.
3: Lamp: an optional indicator lamp can be used to display temperatures above the safe limit when the ignition switch is turned off.
4: GND: Ground
5: T/C-: The thermocouple (-) lead. Usually red lead wire.
6: T/C+: The thermocouple (+) lead. Usually yellow lead wire.
I can provide alarm input/output if needed.
Thanks,
..ed..
___|0o0|___
'04 Excursion PSD (Hers)
'03 F-350 PSD (His)
'05 BMW 325i (Her Daily Driver)
'08 Harley Davidson Fat Bob (His Daily Driver)
'79 Fairchild Republic A-10C
tinygiant is offline
