Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > Off-Topic
Old 09-01-2007, 05:42 PM
Hank Hank is online now
C.P.A. Officer
Ford 2000 Tractor/Hydraulic Question
This should qualify for an Off-Topic Discussion:
I have a 1966 Ford 2000 tractor. I am changing the hydraulic fluid and filters.
1st question - What is a safe solvent to use to wash out the sludge and junk in the housng that won't damage O-rings, seals, etc.? The hydraulic fluid is also the rear axle lubricant.
2nd question: Does anyone out there have a Ford 200 tractor and know how to remove the permanent/reuseable suction filter? The filter is attached to a tube that is on the bottom of the housing under everything else. I can unbolt it from it's support and pull the end of the tube out of it's o-ringed seat, but I can't seem to get the thing out to clean it. I may have to clean it in-place if I can find a safe solvent to use. (See question #1)
Your help wil be greatly appreciated. The so-called tractor forums don't hold a candle to this forum.
Old 09-01-2007, 05:57 PM
Big AL Big AL is offline
Strokin' In Dixie-Land
Hank,
I'm pretty sure that you can use mineral spirits for cleaning. I think it has very little reaction to elastomers. Just remember in handling it, it is flammable.
Someone else may can help you out on the filter (I have a Massey Ferguson with the canister type hydraulic filter).
Good Luck
Old 09-01-2007, 07:53 PM
pipelayerjdh pipelayerjdh is offline
MINI-MOD
I've always used diesel fuel to flush hydraulic systems.
As for the filter, maybe if you take a pic of it, I can remember what to do with it. Its been about 7 years since I worked on one.
Old 09-02-2007, 03:52 AM
C.P.A. Officer
I'll try to take a pic or two after the sun comes up. Supposed to meet a friend at the Dacusville Farm Days today. (Got to work tomorrow.) I was in hopes of running into somebody that could help me there. I have service/maintenance manual but it doesn't address this problem. It just says to clean the suction filter (one I cant get out) and replace the return filter (already on the bench) every 2400 hours or every two years! This tractor is 41 years old and I am almost sure this is the first time. :-) Not sure how many hours.
Do you have a Ford 2000? What year? Gas or deisel? Mine is a gasser.
Old 09-02-2007, 03:52 PM
C.P.A. Officer
Red face Takin' the easy way out.......
Pipelayer:
Pics just don't show enough. Small space to try to photograph. I had a chance to talk with Brian Batson who operates a tractor sales and repair place in Pickens today at the Dacusville Farm Days. He acknowledged that it is almost impossible to get the suction line/filter assembly out without bending it to do so. I have decided to just clean 'er in place with mineral spirits as Big Al suggested and take my chances. What ever I do has to be better than it was after 41 years of neglect.
Thanks for your willingness to help.
I'll post my results.....maybe.........
Know any Agnews down your way?
Hank
Old 09-02-2007, 04:20 PM
MINI-MOD
Originally Posted by Hank View Post
Pipelayer:
Hank
I know a few. Do you know Tom? He's my neighbor.
