Charging Problem - Ford Powerstroke Diesel Forum
Old 06-15-2007, 03:39 PM
RRonning84
Guest
Posts: n/a
Charging Problem
Now this isnt on my PSD but I hope you guys will help just the same. So I have this '97 Blazer in great shape. Every thing on it works great except the dang thing wont start if you let it sit for a while. I have changed the alt, the battery, and checked all the wiring that I can think of for dead shorts. Any ideas?
Old 06-15-2007, 04:00 PM
do a parasitic draw test. Turn everything off and set up an ammeter in series with the battery and start pulling fuses until amperage goes to nothing.
Old 06-15-2007, 04:01 PM
That will tell you what circuit is draining the battery.
Old 06-15-2007, 04:03 PM
RRonning84
Guest
Posts: n/a
Thanks! I didnt know about that but I will give it a try.
Old 06-15-2007, 04:08 PM
Usually the ignition will cause a large draw, so i would be sure to check that.
