ok i need some serious help - Ford Powerstroke Diesel Forum
Old 06-12-2007, 03:17 AM
so i got this new sub and amp and i already have a 4 channel amp to run my four speakers off of.... so i wired up the sub and the amp and this other weird thing that stores power or something... but anyways the three screws on the back of the amp you no where you clamp your battery wire in, the remote wire in, and the ground wire... well the connection screw and the little thing the screw goes into snapped off and now there is now way to get pwoer to it.... any suggestions from you smart electrical people
thanks
Old 06-12-2007, 04:04 AM
duct tape & zip ties
Return AMP to the store you purchased it from. They should warranty it. If you bought it used, then go to a store and buy a new amp.
You maybe able to take it to an electronics repair shop and have them fix it. But by the time you get there bill you could have bought a new amp. Sorry but there is no easy fix for this.
Old 06-12-2007, 01:59 PM
i didnt think so ... it was worth a try though.... man i had everything working perfect and then i got home and decided i was going to organize the wires and then that happend and i stayed up till bout five trying to fix it... frusterating night
Old 06-12-2007, 02:30 PM
where did you get it at?
Old 06-12-2007, 03:03 PM
you can't drill and tap it a little larger? my amps look like they could be tapped..
Old 06-12-2007, 03:21 PM
my step fathers best freind is a rep for alpine so i got through him and i have had it for about three years now so i cant warranty it...
i cant drill and tap it cuz the screw didnt break... its like a little squre of gold plated matel about a 4th of the size of a sugar cube .and on the back is a little metal tab that is about as wide as a candle wick and about 1/8th inch long... it snapped so the metal tab thats on the back of the square of gold plated metal snapped in half so now its so small you can barely feel it... the tab was what was connecting the connection point to the amp.... kinda stupid how easy a 450$ amp can just break and be done for good that easy
