| Off-Topic Discussion of All Non-Related Topics |
Acetone in fuel
Has anybody heard of adding acetone to your fuel in diesels and gassers for better fuel mileage? Apparently the argument is that it thins out your fuel for better atomization...
Im hearing 3oz for every 10gallons in gassers and 2oz for diesels. Better atomization=better fuel mileage.
I have heard about it, but never looked to see if its true or not. But I used to add it to my mustangs gas tank to get it to pass aircare (emissions testing in BC). I have heard it is bad for rubber seals in your fuel system, and especially hard on head gaskets. But this is only what I have heard. Hopefully someone here knows more...
Google "acetone in fuel". It's bunk, not worth trying. Every article I searched said it actually decreased mileage. Myth busters tried it and found the same according to what I read.
i add angorian goat urine to mine it helps with fuel mileage and increaces injector replacement
Thanks guys
I have used it in gas and diesel. Heres a article I found-
WATER CARRYING PROPERTIES OF ALCOHOL COMPARED TO ACETONE:
The water carrying properties of alcohol and acetone are essentially the same. One drop of water in many gallons of either alcohol or acetone will completely dissolve. Similarly one drop of acetone or alcohol in many gallons of water will completely dissolve. Neither can be seperated again without major effort. Obviously the amount of damage to fuel system injectors, etc. is porportional to the amount of water, right on up to pumping pure water through them. 3.5 ozs acetone per 10 gallons gasoline is about a 0.3 percent concentration. ethanol gas contains up to 10 percent of alcohol. NO damage to fuel injected engines is cause by 10% ethanol else it would be forbidden on the market. Therefore the same will apply to acetone concentrations up to 10%. There is no difference in combustion products from acetone compared to alcohol. Both are made up of carbon, hydrogen, and oxygen. Therefore, the water damage done from 10% ethanol in gas will be 50 times worse than that from .3% acetone, as is plainly obvious, and BOTH will depend on how much water you have in your tank from contamination. The alcohol will carry away tank water 50 times faster than the acetone in the concentrations usually used. In the usual trace amounts of water, the ethanol gas will corrode things 50 times faster than acetone use. NEITHER CAUSE ANY PROBLEM, for ethanol gas is used everywhere, and no problems are known to the government or it would prohibit sale of ethanol gas. As for diesel, without getting into the 57 reported mixtures of disel used in USA, you can be sure some diesels have water carriers similar to acetone or ethanol in them, with NO trouble reported or the mixes would be outlawed. Thus any worry about diesel is trival, and about gasoline is zero. Therefore I would ignore worries that using acetone in gasoline would cause injector or pump damage. The numbers simply nullify that worry. |
Allso go to PureEnergySystems.com > News for the benifits of Acetone use.
This thread looks a bit old, but with my latest results, I have to post.
I've been using acetone in my 2005 F250 6.0L since I've bought it (65000 miles at purchase, 85000 now). I have no problems that I didn't already have. The EGR cooler had to be replaced, and it's a bit rough in the cold mornings until it warms up. The acetone (aprox 2 oz per 10 gal) hasn't changed anything. Now, the big ones: My old Ford E150 with the 5.8L gas engine, same amount of acetone per 10 gallons, showed a 15% gain in mileage, and passed the smog test like a new van. Towing 9000 pounds, mileage increased from 6.8 to 9 mpg. I put it in my BMW motorcycle, mileage increases and I can feel a slight power increase. I put it in the wife's car, a 2002 Mercedes Benz S500. I usually get 23 mpg on the freeway, but with acetone, I get 26. But the last smog check showed: CO - 0 (ZERO) NO - 0 (ZERO) HC - 0 (ZERO) The car has 105,000 miles on it. There are those who believe acetone works. I KNOW acetone works. I have yet to have one of those seals or gaskets or injectors fail on me. And I buy the acetone by the gallon from the hardware store. |
