Cylinder wall crack?? - Ford Powerstroke Diesel Forum
Old 12-31-2009, 04:15 PM
Yep, its a 6.0
I bought a 1948 Farmall H. I am tearing the motor down and took out the sleeves. When I removed the sleeves, I found a few hairline cracks in the cylinder walls. They dont appear to be deep, because there is not any water or rust stains on the backside of the sleeves. What action would yall take, Resleeve or what??
Old 12-31-2009, 06:36 PM
Yep, its a 6.0
bump!!!!!!!!!!!!
Old 01-01-2010, 07:26 AM
Yep, its a 6.0
Someone should know???
Old 01-01-2010, 01:24 PM
are you sure they are cracks and not cross hatches
Old 01-01-2010, 01:28 PM
I'm guessing that's why it was sleeved in the first place.
Old 01-01-2010, 01:32 PM
you can actually grind deep into the cracks and JB weld the cracks. then send the block in for machining to get the JB weld machined smooth with the cylinder wall! good luck
Old 01-01-2010, 03:09 PM
Yep, its a 6.0
no...they are cracks for sure. And they sleeved these motors from the factory.
Old 01-01-2010, 04:44 PM
Shade tree mechanic
Got any pics of the cracks Justin?
Old 01-01-2010, 04:48 PM
Yep, its a 6.0
no, and I just got tolooking, they are cracked all the way through the cylinder wall. So i am in the process of finding another block.
Old 01-01-2010, 04:49 PM
do like i said and JB weld the cracks. i have done it numerous times. even to a buddies WAY over powered Duramax. works just fine
