Originally Posted by super_stroke
ok, i'm no electrical engineer so, does any one know of a web site that has a picture of what diffrent electronic parts are and what they do? like what a resistor is and what it does. what a diode is what it does. you get the idea. i got an old cobra 29 cb and "diassembled" it and now am kind wondering what all that stuff is in there and if i can use it on other things.
i dont know of a website....but i can answer those questions. If i can help you in any way with this build, let me know. i can email you a picture of the symbols on a wiring diagram and some info.....
Resistance is defined as the thing that makes current not flow efficently. current is amperage, voltage is electric pressure. this is how you can get 12 volts through a wire with high resistance. there is plenty of voltage, just no or reduced current (amperage). a resistor is a devise that is put in a particular place to either restrict electrical flow, or sometimes they are put paralell to a light bulb. the light bulb has lower resistance, and electricity always takes the easiest path. the electricity will flow through the bulb unless it burns out, then it will go through the resistor because that is the only path. there are other uses but these are the most common
a diode is a componant the basically makes electricity a "one way street". a diodes main function is to only allow electricity to flow one way. a perfect example is your altenator. it actually produces AC electricity....but a diode blocks half the current and therefore DC current is all that gets to the battery, allowing your 12volt DC truck to maintain power.
the biggest thing you need to worry about is amperage.....you cannot allow more current on a circuit than it can safely allow to flow. 10 amps on a 16 gauge wire will create enough heat to cause a fire. this is drastic, but this is what you really need to look for.........Marc
