Dirt Bike Jetting - Ford Powerstroke Diesel Forum
post #1 of 5 Old 04-18-2009, 02:09 PM Thread Starter
benderado's Avatar
Dirt Bike Jetting
Ok so heres the deal, my sister rides an '04 Yamaha TTR-125L. We went out riding today and I couldn't get her bike to start for the longest time. Finally, I took the carb off and cleaned it the best I could out at the riding spot. I found the float to be sticking and a bunch of sediment in the bowl. Both jets didn't seem clogged as I could blow through them fairly well.
After cleaning the carb, it fired right up but ran like crap. The second you put a load on the engine (like going up a hill) it would bog down and just die.
We brought the bike up from Denver and its in Casper now; around the same elevation, but all the Colorado riding we did was up in the 9,000 foot plus range. The bike still ran well in Denver, but it did sit on a trailer for about 3 years with no maintence.
I'm thinking either the carb is still dirty (clogged jet), or the carb needs rejetted.
What do you guys think?
HI.....I'm Kyle
RIP: 1996 F-250 X-Cab Long Bed
Now: 2006 Ram 2500 CC SB SLT 6 Speed
benderado is offline
post #2 of 5 Old 04-19-2009, 04:28 AM
So is there an elevation change or not? You said Denver and Casper are same elevation, but in Colorado you rode at 9000 ft??? If im not mistaken i think its every 2000 ft of elevation change requires a jetting change.
Pulling the carb off and cleaning it one good time is not a bad idea.
Best bet is to do a plug check. Run it wide open and then just kill it, dont let it rev down. pull the plug and check it. That'll tell ya where the jetting is at.
2012 F350
ross3031 is offline
post #3 of 5 Old 04-19-2009, 04:33 AM
geoff thomas's Avatar
Send a message via MSN to geoff thomas
May sound silly but have you checked your air filter? cleaned and re oiled?
2000 7.3 lariat
8" custom lift
24" Dub Hustla rims 37" toyos
Foil delete
Muffler delete with straight piped stainless side dump
geoff thomas is offline
post #4 of 5 Old 04-19-2009, 04:55 AM
duct tape & zip ties
bigcountrysg's Avatar
I would take the carb off and take it to a shop. Have them steam clean it and rebuild it. To me it sounds like the carb is in need of a rebuild. Also if you tell the shop the specs of the bike. Like after market exhaust, sprocket teeth, what type of air filter your running. When the shop rebuilds the carb, they can jet it for the elevation and modifications you have done to the bike.
Your Actions Today, Decide Your Future Tomorrow
2005 6.0 Crew Cab Long Box Lariat, current truck
2004 6.0 destroyed by contaminated fuel
2002 7.3L burnt
bigcountrysg is offline
post #5 of 5 Old 04-20-2009, 04:37 PM Thread Starter
benderado's Avatar
Well, I dove a little deeper into the carb after I washed all of the mud off. It turns out the float was still sticking. Apparently the gas was never drained outta the carb when it was put on the trailer 3 years ago and all the old fuel gummed up.
I took the float apart and cleaned everything really well with carb clean, blew out the jets with compressed air, and reassembled everything.
Bike started right up, would idle (after playing with the idle screw a bit), and ran a whole lot better.
HI.....I'm Kyle
