'94 suzuki sidekick offroader - Ford Powerstroke Diesel Forum
post #1 of 7 Old 04-16-2008, 04:02 PM Thread Starter
deiselboy's Avatar
hello my dad and i have a '94 suzuki sidekick 4x4. So far we have added a 2-inch body lift and 2-inch suspension lift. We had a problem when we got it about an oil leak, we thought it was the crank case seal when we took it to a mechanic when the head gasket blew e kew it probably did because it as lousing antifreeze. he said that the bolts on the head were barly finger tight but he replaced all the seals. We replaced the radiator and it was still lousing antifreeze so we thought that the head was warped and its been in the shop for about 6 weeks with no improvments.
deiselboy is offline
post #2 of 7 Old 04-16-2008, 04:06 PM
Other vehicle is an F250
Hank's Avatar
Sounds like an interesting project. Got a question someone on here may be able to help you with? Oh ...and welcome to the org.!
2001 F250 Lariat Crewcab, Automatic, 4X4
(Late '99 Regular Cab Work Truck)
6.5" Pro Comp Lift ~ Traction Bars ~ Son-Built Sliders ~ 16" Pro Comp Xtreme Wheels with 35" BFG TA KM2s
4" Banks Exh.-Power Elbow ~ Wicked Wheel ~ DIY AMSOIL EaAU4090 Intake ~ PHP 6 Pos Chip ~ LowDown LED Upgrade
Stage 1 Injectors ~ HankDaddy
Mod. ~ BUILT TRANNY! 352 HP Shootin' for 375!
CAROLINA POWERSTROKE ASSOCIATION
Hank is offline
post #3 of 7 Old 04-17-2008, 02:47 PM Thread Starter
deiselboy's Avatar
yeah I need to know how much it will cost to straghten the head it's only a 4-cylinder.
post #4 of 7 Old 04-17-2008, 11:32 PM
TEXCRAWLER's Avatar
I have a 95 Sidekick 1.6 16Valve in my Samurai. Theres not anything you can do to strengthen the head. Take head to a machine shop and have the head milled down so it will be a flat surface to the block. Normaly the blocks don't go bad. For more info on your suzuki go to Zukikrawlers most the time you can fined out anything you want to know about a suzuki there.
2009 F450 CCLB Dully 4x4. Stock for now.
1997 F350, 4x4, CCLB, S&B cold air, 4" MBRP, stage 1 full force injectors, T4 turbo kit. Terminator 500 hpop, 6.0 inner cooler, 6" Reverse shackle on super duty axles, E-Fuel system, EGT/Trans/Boost gages, air bags, train horn
(2) V8 rock 4 seater buggies. Rockwells,54's BLAH BLAH BLAH BLAH
TEXCRAWLER is offline
post #5 of 7 Old 04-23-2008, 04:03 PM Thread Starter
deiselboy's Avatar
How long should it take to straghten the head
'94 suzuki sidekick
2" body lift
2" suspension lift
31" tires
post #6 of 7 Old 04-24-2008, 11:02 PM
TEXCRAWLER's Avatar
By this you mean make it flat not warped? It should only take a few days depending on how busy they are.
post #7 of 7 Old 08-18-2011, 08:00 PM
Originally Posted by TEXCRAWLER View Post
I have a 95 Sidekick 1.6 16Valve in my Samurai. Theres not anything you can do to strengthen the head. Take head to a machine shop and have the head milled down so it will be a flat surface to the block. Normaly the blocks don't go bad. For more info on your suzuki go to Zukikrawlers most the time you can fined out anything you want to know about a suzuki parts there.
holy moly bump buddy! that is what i need! i will just ask questions on that site. ive been dealing with oil leaks in my zuki. i just want it fixed first. ive been also thinking of selling it since i only use it maybe 2 times a week. i just love my truck but not my zuki anymore. who is interested in getting it? let me know i will email you the pictures and we can talk about the price. thanks.
greywarden is offline
