help me out! what model atv is this? - Ford Powerstroke Diesel Forum
Old 03-21-2012, 02:08 PM
i know its a suzuki, and its relatively old. i got it for free, its 4x4, thats about as much as i know. if you need more info just ask and ill find somethin out. and might be needing some body parts for as cheap as possible. used or new, dont matter. here are some pics
thanks yall!
Old 03-21-2012, 02:45 PM
Looks just like my father-inlaws little 300cc 4x4 suzuki , I can't remember the model but it is like a yr2000 I'll find out the model and get back to you. The plastic will most likely interchange.
Old 03-21-2012, 03:03 PM
pretty sure its a 90's king quad.
Old 03-21-2012, 03:05 PM
pretty positive it is. you can pull the vin and call a dealer.
Old 03-21-2012, 04:38 PM
Yeah I thought either king or eiger but I think the eiger is a newer model, and the small king quads have changed very little over the years.
Old 03-21-2012, 05:44 PM
Yeah the vin on the rear is partially torn off and such... And other location for a vin? I know my sportbike had the vid on the frame, swing arm and engine. Not sure about these things. Neighbor thinks its a mid 80's early 90's lt250 or 350
Old 03-21-2012, 06:04 PM
It's a Kingquad, probably a 250. They are absolute tanks. There is a sticker under the front. They will fit anywhere, I had 2.
Old 03-21-2012, 06:32 PM
suz 4x4
vin should also be stamped into the frame where the steering head bolt goes through.
Old 03-21-2012, 06:34 PM
I tried lookin under the front and didn't spot one to quickly, a little more of an idea where it could be at?
Old 03-21-2012, 06:40 PM
its a mid 90's i think too. maybe check on the motor to see if it has a vin on it. it might be able to narrow down the years. my vin was only on the frame. im sure its there somewhere..
