E 350 van conversion ZF 5 spd? - Ford Powerstroke Diesel Forum
Non-Powerstroke General Discussion General Discussion for 6.9L and 7.3L IDI (Non-Powerstroke) Engines
Old 03-16-2009, 05:44 PM
Hello Folks,
I have a 1994 non turbo pre powerstroke Econoline 7.3 idi E350 with quigley 4x4 conversion. final gear 1-- 4.09
The auto transmission with overdrive is shot, no movement in any gear.
I would like to convert the van to a manual transmission.
Quigley used a converter piece to connect the transfer case to the original auto transmission
Did anybody do this?
Any idea what flywheel I would have to use, dual mass or normal form 6.9?
Would a 5 spd ZF 4x4 bolt up to the transfercase, or would it be possible to use 5 spd ZF 2wd and use the quigley converter?
What problems to expect adding a clutch pedal?
Better to go with hydraulic or cable driven clutch ?
Use parking brake mechanism as clutch pedal and add parking brake handle on side of seat?
Thanks for any insights
J
Old 03-17-2009, 03:57 PM
bump bump bump
