| Non-Powerstroke General Discussion General Discussion for 6.9L and 7.3L IDI (Non-Powerstroke) Engines |
ALCHOL POWERED
I'm looking for help run alchol for fuel. What I have is a custom built (by me) 1600lb pullung tractor powered by a 2300 ford 4cyl. holley 500 cfm carb, I ran it on gas this year but I need to step it up a little and run alchol for next year but I dont have a clue where to start.
Cmon there has to be at least one drag racer on here
You'll need a fuel pump compatible with alcohol, and an alcohol carb. May be other stuff also, but these are a must. |
if you wanna go mechanically fuel injected call rons fuel injection
if you wanna stay with a carb call davincci but you will need to make sure the foam in your fuel cell is compatible with alcohol and you need a pump that is compatible basically everything needs to be compatible lol and be prepared to change your oil alot because alcohol eats it up bad |
