92 hard to start when warm - Ford Powerstroke Diesel Forum
Non-Powerstroke General Discussion General Discussion for 6.9L and 7.3L IDI (Non-Powerstroke) Engines
post #1 of 5 Old 01-07-2008, 04:26 AM Thread Starter
trampsdiesel's Avatar
92 f250 7.3 non turbo new glow plugs.starts great when cold but after it is shut off for 30 minutes and i go to start it it just spits ang grunts for a second then stalls and wont start.i thought it would be the warm idle or the cold start solenoids.i have a parts truck but i dont know what the solenoids look like.
trampsdiesel is offline
post #2 of 5 Old 03-13-2008, 11:19 AM
fordrunner's Avatar
hard start when warm
i am having the same problem. Just bought the truck two weeks ago. it starts right away in the morning, but when i drive it for 10 to 20 miles then part for 30 minutes, it would not start anymore. i replace glow plug relay, fuel filter, checked FSS, replaced two new batteries and still does that routine. I am planning on replacing the starter today am just so frustrated at this point. I drove it once to get to my doctor's appointment, and i ended up towing it back home and yes- all glow plugs are functioning, fuel delivery are good...etc.
fordrunner is offline
post #3 of 5 Old 07-27-2010, 04:41 PM
I am having the same problem with my 93 f 350.?????
jcappeljr is offline
post #4 of 5 Old 07-27-2010, 07:08 PM
FordGuy100's Avatar
The first thing that comes to mind is your guys IP's are on there last leg. As they were the tolerances inside them become "looser". It gets to the point were the tolerances become to much, and when warm (since metal expands) they become even larger. So you try to start and the tolerances are to far apart so the IP can't push fuel out at high enough pressure.
To test: next time this happens take a full water bottle with Luke warm water not ice cold and pour it over the IP. If it starts, because the water cools the case and brings tolerances closer, you knwo you need an new IP.
-Justin-
1985 Ford F-250 with a 6.9 IDI/T-19 4speed 4x4
Paint, Eagle Alloys, Kelly Safari TSR's, ATS turbo, gauges
2004 Jetta TDI 5 speed
2004 2wd Excursion Limited 6.0. Testing how loyal I am to Ford
1997 Passat B4V TDI. 1 of 80 imported in 97. 50 MPG and a factory 25 gallon fuel tank!
FordGuy100 is offline
post #5 of 5 Old 07-27-2010, 07:09 PM
FordGuy100's Avatar
Also don't do this more than a few times because you can being the tolerances close and break the IP shaft meaning you would need a whole new IP
-Justin-
