Evening,
I have worked around with my 1989 IDI for sometime now to try and figure out what is causing my cold crank issues. At first I assumed it was mainly a cause of it being cool outside, but then realized then even when it is cool outside it still will crank (with or without the block heater), but it shuts off soon after (maybe 10 seconds later). After it would shut off, it takes a good bit of work (turning starter over and over for some minutes to get it running. Sometimes I simply come back to it later as the battery and starter are beginning to get slow) to get it running.
Now I have found that the cold crank issues are non-existent if I have ran the truck in the last day. Meaning, if I started it yesterday, and even if it is cold outside, it will start and run smoothly today. Now, if I let the truck sit for longer period of time, days, this is when I get the first crank with the shut off seconds later and the time spent turning the starter.
I am not a mechanic by any means, but it seems to me that the truck is loosing its prime. Seems to me it is starting up and burning the fuel in the filter area, shutting off, and then me turning the motor over with the starter is creating pressure or re-priming the fuel.
Any direction would be appreciated. I feel confident in my glow plus system now, and the longer I have the truck it seems I am getting the exact issue handled. With it being our "work" truck for our house, there is not a lot in the budget to take it to the diesal shop
Thanks ahead of time for all of your help.
Cheers
