Fuel tank Pickup foot options - Ford Powerstroke Diesel Forum
Non-Powerstroke General Discussion General Discussion for 6.9L and 7.3L IDI (Non-Powerstroke) Engines
Old 08-04-2011, 09:47 PM
I am down in Mexico so getting parts is sometimes hard. But I could not find the fuel tank pickup foot even on rockauto.com.
so read a few people who just use rubber tubes and cut a v in the bottom and use a hose clip.
because there are so many lose parts from my broken up pickup foot I want a strainer. So I am doing the following and want some Ok or no go from some of you who have a little more experience.
I am using a car in tank gas strainer and adding a two way barb and making a good seal with a couple harbor freight o-rings I have to fuel line tubing. I have enclosed the pics, I do not know what the length should be of the tubing, but will work on that later.
does anyone have any comments before I do this....
assembled
http://www.la-ventana.com/P1010068.JPG
http://www.la-ventana.com/P1010070.JPG
and assembled more. will shorten the hose once I figure out correct length. if no one can tell me it will be trial and error...
Old 08-05-2011, 10:45 AM
here is my final
Here it is ready to go back in the truck, with cutting the barbs it is metal to metal with hose and hose clamps. i also added a small diversion with a 1 inch right angle coper tube on the return line. so the bubbles are a bit farthur from the supply line. I had to slightly smash the 1 inch tube to be a bit oval to fit on the guel guage sending positiner. I did not interfere with it. I also used some brass wire to tie it up as a back up.
here is the cut off of the barbs. removed 2 barbs and it is a perfect fit.
http://www.la-ventana.com/P1010071.JPG
here is finished unit
http://www.la-ventana.com/P1010077.png
here is high resolution of the job
http://www.la-ventana.com/P1010076.JPG
Old 08-06-2011, 07:29 PM
finished the rear tank today, so both are up and running and can now go to E and run..
I think only us 7.3 diesel owners can proudly say we are happy when we are on E on both tanks.... Only we will understand...
Old 11-10-2011, 06:55 PM
got any lenghts to share as i am going to do the same thing. and strainer part number.
