83 INJEC pump - Ford Powerstroke Diesel Forum
Non-Powerstroke General Discussion General Discussion for 6.9L and 7.3L IDI (Non-Powerstroke) Engines
post #1 of 8 Old 04-17-2011, 05:03 PM Thread Starter
Big_Red_Stroker's Avatar
83 INJEC pump
ok guys we have a 83 6.9 that needs an injection pump. im a 7.3 guy and need some input please!
Trevor
NEW MOTOR BEING BUILT! motor thats in it right now....7.3,DI stage 4s 350/200s, GT4594 turbo, ZF5 swap, Valair Kevlar clutch, term twins HPOP, 6" lift, 35",Banks IC, DIY 6637 filter, 3.5" down pipe, BDP IDM, TW live tuned chip, BD turbo timer, DIY ladder bars,910 springs, push rods, studs, fuel and airdog I.
SOLD 99 F350 CCLB 6speed 4in down pipe. and banks junk, made 330 on the dyno at 5k feet though. 2.5in leveling kit. custom bumper.
1983 F250 6.9 IDI, 4X4, Flat bed
Big_Red_Stroker is offline
post #2 of 8 Old 04-17-2011, 07:17 PM Thread Starter
come on any one! if this was a 7.3? 20 guys would have said something
Trevor
post #3 of 8 Old 04-18-2011, 05:20 AM Thread Starter
bump for the morning
Trevor
post #4 of 8 Old 04-18-2011, 02:10 PM
FordGuy100's Avatar
What do you need to know?
-Justin-
1985 Ford F-250 with a 6.9 IDI/T-19 4speed 4x4
Paint, Eagle Alloys, Kelly Safari TSR's, ATS turbo, gauges
2004 Jetta TDI 5 speed
2004 2wd Excursion Limited 6.0. Testing how loyal I am to Ford
1997 Passat B4V TDI. 1 of 80 imported in 97. 50 MPG and a factory 25 gallon fuel tank!
FordGuy100 is offline
post #5 of 8 Old 04-18-2011, 07:41 PM Thread Starter
never done one and need to know alot i guess lol
Trevor
post #6 of 8 Old 04-21-2011, 07:21 AM
FordGuy100's Avatar
Easiest way is to pull the intake manifold off. Then te IP has three bolts holding it to the cover. Do not take the cover off, don't do that. Just those three bolts that hold it to the cover. Then remove the oil filter neck, this will expose where the IP bolts up to the gear. Take out those bolts. IP has a dowel to keep the timing within spec.
Forgot to mention, all injector lines need to
Come off.
-Justin-
post #7 of 8 Old 04-22-2011, 07:58 PM Thread Starter
ok thanks man! hey if i have any more ?s can i just call J-rod to get ahold of you?
Trevor
post #8 of 8 Old 04-22-2011, 11:47 PM
FordGuy100's Avatar
Yeah that's cool just get ahold of jarrod to get to me.
-Justin-
