90 F250 7.3 idi COld/Hard start...HELP! - Ford Powerstroke Diesel Forum
Non-Powerstroke General Discussion General Discussion for 6.9L and 7.3L IDI (Non-Powerstroke) Engines
Old 02-08-2011, 09:36 PM
Exclamation 90 F250 7.3 idi COld/Hard start...HELP!
SO my grandpas 90 7.3 idi is having trouble starting when its cold, he said it would take him around 2 minutes of cranking b4 it will even start.
but when its warm it starts like normal.
My guess is its The Glow plug relay, OR the glow plugs....anyone ever had trouble like this b4???
Im trying to keep the Blue Oval in the family
any help would be great ....
Old 06-10-2011, 07:37 AM
Definatly not a glow plug problem. Let me guess, the longer it sits the harder it is to start.
What you have here is a classic "idi air intruson" problem. The truck is loosing it's prime. air leaks in and the fuel runs back to the tank. then you spend a couple minuets pumping fuel back up to the injection pump. Thats a good way to burn upa starter quickly. Then the weak starter will not spin the motor fast enough to crank it right away either.
It's commonly the rubber lines and/or the o-ring under the plastic caps on the injectors. The repair kit's are pretty affordable from many different vendors.
Mine ended up being a check valve inside the fuel lift pump. And another new starter. After i did my lines and hoses first, and that still didn't solve my problem.
Do a search and you will learn allot about that classic Ford idi problem.
YMMV Sean
Old 06-11-2011, 04:37 PM
Oh thanks man. To bad he got rid of his truck to Pay for a surgery. :|
but Thanks for the interest in helping
Old 06-11-2011, 06:16 PM
Figures, a day late and a dollar short.
I've been fighting with mine for like 2 yrs. Just recently threw in the towell and finally found a local shop that could work on the "Old Diesels" that arn't plug and play.
Money well spent! Cranks right up after sitting more than a day. FINALLY! Now I an put a bed on it and put it to work!
YMMV Sean
Old 06-11-2011, 06:20 PM
what kind of truck do u have? any pix
Old 06-11-2011, 07:45 PM
Just put some of the new truck, the 92 in my gallery, Check it out. Will have to get some of the 86 to add to it later.
YMMV Sean
Old 06-12-2011, 04:55 PM
is it the black one? whos dually is that. its cleannn
Old 06-12-2011, 06:38 PM
Dually is a 97 powerstroke auto 2wd with 210,000 on it. I use to own it and sold it to a buddy that lets me borrow it anytime i need it. He pulled the 4.10 gears and put in 3.55's to streach it's legs and drop some rpm's.
I would've bought it back except I need a 4dr 6 seater now with my new larger family.
It actually has a full "Choo Choo Customs" package on it and inside and out. Body colored running boards, air dam, visor, tail light covers, even had body colored vent gaurds, plus leather and wood grain inside. It needs a repaint, but thats what he dose.
