Update on 94 idi turbo - Ford Powerstroke Diesel Forum
Non-Powerstroke General Discussion General Discussion for 6.9L and 7.3L IDI (Non-Powerstroke) Engines
post #1 of 6 Old 12-07-2010, 08:37 PM Thread Starter
takif350's Avatar
Well picked her up on Saturday morning in Chicago in the ice cold with 3 inches of snow on the ground and more coming down. The truck is in better shape than I expected drives really good and is a lot quicker than I expected. I drove it home Sunday 764 miles with out a hiccup and she even started on the second try in the morning in the 12 degree weather without being plugged in all night I was wondering what oil and filters you guys are using on yours and intervals for fuel and water separator filters?? I also want to thank everyone who answers all my other questions and will have pictures on here soon
takif350 is offline
post #2 of 6 Old 12-08-2010, 08:51 AM
FordGuy100's Avatar
Replace the fuel filter at least once a year. Fuel filter is also a water seperator on your truck.
As far as oil, thats everyones own opinion. Rotella, motorcraft, delo, they all do fine.
-Justin-
1985 Ford F-250 with a 6.9 IDI/T-19 4speed 4x4
Paint, Eagle Alloys, Kelly Safari TSR's, ATS turbo, gauges
2004 Jetta TDI 5 speed
2004 2wd Excursion Limited 6.0. Testing how loyal I am to Ford
1997 Passat B4V TDI. 1 of 80 imported in 97. 50 MPG and a factory 25 gallon fuel tank!
FordGuy100 is offline
post #3 of 6 Old 12-08-2010, 10:04 AM
Texas6.0's Avatar
Power Stroke oil filter #FL-1995 holds an extra quart and offers better filtration.
Fuel filter every other oil change.
'94 F-350 CC DRW 2WD Turbo IDI 7.3
Rebuilt E4OD w/"updates" & billet Precision "RV" TC
Custom welding Bed/Lincoln Classic II
Helper Bags
3" straight pipe w/one-off 6" SS tip
K&N Air Filter
Pioneer HU/Alpine components
7 235/85-16's (spare tire holder is modded for a bigger than stock spare)
FL-1995 & new ZD9's
Next: whenever the OEM injectors go out they will get replaced with BB codes
Texas6.0 is offline
post #4 of 6 Old 12-08-2010, 10:33 AM
FordGuy100's Avatar
Agreed with the powerstroke oil filter, though some people have clearance problems with them. Its tight but it should fit, and does offer a lower micron rating so filters better.
-Justin-
post #5 of 6 Old 12-08-2010, 03:41 PM
ryandamo's Avatar
i was wondering about using a powerstroke oil filter, did some engines have different oil pans? not to hijack
2016 F450 6.7L XLT 4x4Dump, bone stock
1994 F250 7.3L XLT 4x4 ZF5 , Centurion, 4" Lift, 6637, Gulf Coast Bypass Filter, Big fuel tanks, dana 60 swap, No longer dually
1997 F350 7.3L XLT 4x4Dump, E4OD, 4 in exhaust, TS 6 position, 3/8 Trans line+external filter
2013 Scag Turf Tiger 61" 1.1L Caterpillar Diesel
1960 John Deere 440 Backhoe 2-53 detroit
ryandamo is offline
post #6 of 6 Old 12-08-2010, 04:02 PM Thread Starter
takif350's Avatar
Will do I do have two questions after driving when I shut it off it leaks a few drops of oil by the balancer I took a look at it but it seems to be coming from higher up is there any hoses or oil lines up over the crank?? And sometimes at highway speeds it seems like there is no boost other times it pulls like a raped ape whats up with that ??
takif350 is offline
