help - brake problem - Ford Powerstroke Diesel Forum
Non-Powerstroke General Discussion General Discussion for 6.9L and 7.3L IDI (Non-Powerstroke) Engines
post #1 of 6 Old 11-01-2010, 12:10 PM Thread Starter
Hey guys,
I've got a 92 F350 7.3 truck. And I am having some brake problems with it.
When I push on the brake it goes to the floor real easy and then stays there for a little bit, Then it will just come back up. And also, if I just tap the brake, it will go down a little bit and then come back up by itself.
I was thinking it's either the vacuum pump or the brake booster.
Any help would be great.
Thanks,
Norayah
melvin92 is offline
post #2 of 6 Old 11-01-2010, 12:40 PM
shhhhh, can you hear it?
08pwrstrokr6.4's Avatar
have you checked the fluid and for any leaks around the truck and master cylinder?has it been getting progressively worse?
Patrick
TAPS Historian
08 6.4L ECSB
S&B intake,H&S Black Maxx,5" Pipe,Trac. Bars
13.77@100.63
OIF 07-08 16 months OIF 10/OND 10-11
Originally Posted by Diesel Tech Mag
All you need is a little knowledge,the right tools, and a buddy's truck to practice on.
08pwrstrokr6.4 is offline
post #3 of 6 Old 11-01-2010, 12:44 PM
rankroddin250's Avatar
My brake pedal squashed to the floor and i found out my front wheel bearings went out and the front brakes where the only thing holding the front wheels on! might check that out.
A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
The People of a free country should not be scared of their government, the government should be scared of their people.
rankroddin250 is offline
post #4 of 6 Old 11-01-2010, 12:54 PM
how did you not feel the bearing out until then?
Patrick
TAPS Historian
08 6.4L ECSB
13.77@100.63
post #5 of 6 Old 11-01-2010, 01:44 PM
Dunno it was pretty weird! nothing acted wrong until the brakes went out then when I took my calipers off the front rotors pretty much fell off. hubs, bearings, seals an spindles where all toast! they didn't make any noise or any thing b4 that.
post #6 of 6 Old 11-01-2010, 05:12 PM Thread Starter
Yeah, I did. I even bled the brakes and still same problem. Another thing I noticed when I drove it today, is that when I was driving, every now and then the brake would just go to the floor by itself. So I would have to drive with my foot under the pedal.
melvin92 is offline
