Here is my first IDI. - Ford Powerstroke Diesel Forum
Non-Powerstroke General Discussion General Discussion for 6.9L and 7.3L IDI (Non-Powerstroke) Engines
Old 09-19-2010, 01:25 PM
Here is my 1994 F250 XLT factory turbo 7.3L
Auto O/D trans, 234,000 kms, no rust.
Just a few questions now.
It has been a week since I got her, after I was messing around with the air filter the next time I started it up, it gave me trouble and blew out white smoke on start up. I wonder If I hit one of the old return line caps and caused a small leak. I have looked up return line kits and the factory turbo one seem to cost double the price. Is there a brand you guys would recomend?
To me it looks like the front springs are sagging and need to be replaced, is this true?
thanks.
Old 09-19-2010, 01:34 PM
OBS springs are all like that.
Welcome to the ORG
Sask here.
Old 09-19-2010, 05:34 PM
Yeah the springs are like that. You can level it with an add a leaf like I did and it wont make the ride rougher. I cant tell a difference
Old 09-19-2010, 08:05 PM
Those add a leafs look like a good fix.
Any allignment adjustments required after the install?
Old 09-20-2010, 03:54 AM
Yeah. Was told they wouldnt need to be aligned but they do.
Old 09-25-2010, 10:46 AM
Those are reverse arch springs, used with the TTB front axles. Thats just how they are. I think the 4+" lifts come with positive arch springs. Anyways its good to get TTB's aligned anyways cause they are always a little off. I know mine is.
Return line kits are basically a "one size fits all" if they want to charge you double thats a little crazy. Where are you looking? A guy on another board sells return line kits with viton O-rings (good for bio and the new USLD diesel). If you want contact info let me know. I bought a ton of stuff from him, good guy.
Old 09-26-2010, 05:11 AM
check your coolant for the spcaial additicve that prevents cavitation, it can be a particular problem in a 7.3 if not addressed.
Old 09-27-2010, 06:54 AM
NOT a Democrat
Are you always getting the smoke at start up? I replaced the airfitler on one of my older rigs and it did the same thing but only on the 1st start up.
