| Non-Powerstroke General Discussion General Discussion for 6.9L and 7.3L IDI (Non-Powerstroke) Engines |
Hey all..the other day i was offered a 1994 F250 IDI factory turbo for $2,600. The truck has 220k on it, new ball joints, new pump and stage 1 dps injectors (1000 miles on them) a shift kit, full gauges, new lockouts, has been serviced regularly, and additives have been used in the coolant. Has a stainless turbo back to an 8" mitre.
The bad.. It has a cracked windshield, some rust, most of it has been patched (not sure how good) it needs paint and from what i can tell alot of tlc. dents, scratches, by far not pretty. I don't know if a truck in this shape is worth $2,600 or not? I'm in need of some advice, and this would be my first diesel purchase |
It sounds like the truck is in great mechanical shape, so I would say go for it. Now... Keep in mind it is quite eye-retardant right now, but maybe 3000 in body work spread out over time and you'll have a truck you can beat on for the next 15+ years.
Thanks for the input powerhoghp, I'm fairly new to the IDI Turbo engine and all..just needin some help from the org
Just found out the truck has a leaking return line, how hard of a fix is that?
Real easy and a shop could do it for less than $150 (roughly).
I would say offer $2200 (thats what I think its worth). If he doesnt bit then say the $2450 since you are going to have to get new return lines installed. The only reservation I have is that if the body looks that bad how good a shape is the rest of the truck. Also, that huge exhaust pipe doesnt make me think he was nice to this rig...... I would test drive it cold and hot. just to see if it has any issues! Good Luck Thad |
i say go for it. sounds like a good rig.
Thanks guys
Ditch the injectors and get stock ones. They are probably the worst injector you can buy. Horrible spray pattern, horrible pop pressures. Make your truck idle like it has a big cam, throw out a bunch of black smoke.....if you like that ok. BUT they will make your truck get horrible fuel economy. Up to you.
Thanks for all the input guys. I decided not to go through with it.
