newb with a question - Ford Powerstroke Diesel Forum
Non-Powerstroke General Discussion General Discussion for 6.9L and 7.3L IDI (Non-Powerstroke) Engines
Old 04-06-2007, 06:56 PM
well ive been searching but cant seem to find what im looking for.
i just picked up a 1994 f250 with the 7.3l turbo non powerstroke and my question is whats the difference
will things for powerstrokes work ie exhaust chips ?
this truck was bought to make a WVO rig and it will be but i just want some info on the engine
thanks in advance
Old 04-06-2007, 07:42 PM
BIG TRUCK, SMALL DRIVER
Most parts will not interchange. The powerstroke has a completely different fueling system. It uses a type of electronic fuel injection where yours has a mechanical fuel injection pump. The programming is totally different, so chips will not interchange. You can do most of the same type mods as powerstrokes. High flow intake and big exhaust will help. You will probably need to modify powerstroke kits or make your own. You can turn up the injector pump for more power so you don't need a chip.
Old 04-08-2007, 04:24 PM
kool so do these engines react the same to the normal mods intake / exhaust?
meaning the bigger the better
thanks for the info
Old 04-08-2007, 04:27 PM
im fat and ugly
welcome aboard
Old 04-10-2007, 08:39 PM
Send a message via AIM to rufushusky
thanks for the info
Well bigger is not always better, a 5" exhaust will not help a sub 550+ rwhp truck anymore than a 4". In fact you will have a little less low end torque thanks to eddies in the exhaust. So an intake and a 4" exhaust is a good starting place, then I would do some gauges!
Old 04-11-2007, 07:37 AM
great thanks guys
Old 05-05-2007, 10:23 PM
SMOKE ROLLER
Welcome 2 the ORG...
Old 05-06-2007, 10:11 AM
CW4 Retired, US Army
I can't help with your problem (still learnin' myself)
but Welcome Aboard !!!!!
