Go Back   Ford Powerstroke Diesel Forum > Pre-Powerstroke Diesel Section > Non-Powerstroke General Discussion
Non-Powerstroke General Discussion General Discussion for 6.9L and 7.3L IDI (Non-Powerstroke) Engines
Old 11-03-2009, 06:11 PM
RadarRider RadarRider is offline
Central Scrutinizer
Question Royal Rumble
I've noticed since I got my IDI, before & after the "Big Fix", it's had a rumble or I guess a vibration between 65-75mph. I've replaced the u-joints in the rear driveshaft & front axle(haven't touched the front driveshaft yet, but I'm sure that wouldn't be the cause). I was wondering if it could possibly be the tires. I've got BFG Commercial T/A 245/75R16s on it & I don't know how many miles the previous owner drove on them, but they're in really good shape & have no other signs of damage. The tread looks semi-aggresive. It's more like a snow tread than an all-season tread but they don't "hum" it just vibrates. If you don't think it's the tires, what else should I try?
Old 11-03-2009, 06:17 PM
RRonning1984 RRonning1984 is offline
Heavy Equipment 911
Well it could be the tires. Mine vibrate at speed because of my tread.
Old 11-03-2009, 06:20 PM
dalton1 dalton1 is offline
Have you had the tires/wheels balenced?
that is almost always what causes a vibration at 60+mph
Old 11-03-2009, 06:24 PM
Central Scrutinizer
But do you get a hum or vibration, Ryan?
I haven't gotten the tires balanced as the previous owner said he had it done when he had the tires put on. I have no idea how long ago that was. The other thing is, the vibration kinda goes away @ 80ish. Still there but NOTHING like 65-75mph.
Old 11-03-2009, 06:44 PM
Mototime2000 Mototime2000 is offline
A vibration that comes and goes at different speeds can be tires. I had a vibration in my 2.3 Mustang and come to find out one of the U-joint clip came out and let the cap walk outward causing a 1/16th of an inch of play and it would shake the whole car at 65 mph.
Old 11-04-2009, 05:39 AM
Central Scrutinizer
After you posted this, I double & triple checked my u-joints last night. 1st I checked the u-bolts that hold the rear u-joint in & they were OK. I also checked the lock rings on the front & rear u-joint & they were all OK. Then I got crazy & pulled the driveshaft out to make sure both u-joints didn't have any resistance & everything checks out fine. I reinstalled the driveshaft & took it for a quick ride on the highway & I'm still getting the same thing. The next thing I'm gonna try is flushing out/refilling the diffs. That's another thing that came to mind. If it's not this, the tires have to be the culprit.
Old 11-06-2009, 04:04 AM
cndrm cndrm is offline
Before you mess with the diffy's, I'd take it in and have the balance on your tires checked out. As tires wear down, their balance can change. Also, they might have been in balance, and you could have thrown a weight or two. (I've had this happen a lot, especialy with the smaller weights)
mike
Old 11-06-2009, 02:48 PM
Central Scrutinizer
mike
I'll give it a try. Thanks, man!
