Water Separator - Ford Powerstroke Diesel Forum
Non-Powerstroke General Discussion General Discussion for 6.9L and 7.3L IDI (Non-Powerstroke) Engines
post #1 of 3 Old 10-12-2009, 02:43 PM Thread Starter
95Dually7.3's Avatar
Water Separator
My friend has a 86 F250 6.9 with a aftermarket banks turbo kit. He is trying to located the fuel water separator we cannot seem to locate it. Does any one know where I can find the water separator on the 6.9. I am not sure if it had to be relocated beacause of the aftermarket turbo or not. The water separator is not located on the firewall where it suppose to be.
95Dually7.3 is offline
post #2 of 3 Old 10-13-2009, 09:08 AM
04_6.0's Avatar
Very possible it has been bypassed and removed from the vechile. The factory one can be quite a pain because of air leaks and such; because of wore out gaskets. Only thing i can tell you is start at he the filter head and trace your way back to the tank. If there isnt a seperator there then it has been deleted. On my truck when i bought it, it was removed and a wix filter head with a fuel/water seperator filter was mounted under the truck.
04 6.0 ZF, 4x4 CC SB.
"You say im premature i just call it ecstacy"
"A Chuck Norris-delivered Roundhouse Kick is the preferred method of execution in 16 states."
04_6.0 is offline
post #3 of 3 Old 10-16-2009, 01:29 PM
FordGuy100's Avatar
Stock seperator will be on the firewall in between the brake master cylinder and fender (it will actually be down about 10" from that, kinda down in that area). It has a pull chain thing on it to release the water. The 6.9 setup sucks, most bypass. Mine doesnt even work, stuck with the chain in the drain position. Doesnt suck air and it always gets ride of the water LOL
-Justin-
1985 Ford F-250 with a 6.9 IDI/T-19 4speed 4x4
Paint, Eagle Alloys, Kelly Safari TSR's, ATS turbo, gauges
2004 Jetta TDI 5 speed
2004 2wd Excursion Limited 6.0. Testing how loyal I am to Ford
1997 Passat B4V TDI. 1 of 80 imported in 97. 50 MPG and a factory 25 gallon fuel tank!
FordGuy100 is offline
