6.0 hybrid - Ford Powerstroke Diesel Forum
post #1 of 6 Old 07-21-2013, 08:45 PM Thread Starter
sprksonu's Avatar
6.0 hybrid
So I decided to head to the resort for the weekend and could not find a parking spot until I ran across this little gem, it is a parking spot for hybrids or electric cars. I carefully backed in then pugged the ole girl in. My question is my charge indicator is not showing? Any help would be much appreciated!6.0 hybrid-imageuploadedbyag-free1374464746.395624.jpg
WRECKED EM DAMN NEAR KILLED EM!
2005 f250 ccsb 4x4 Studded, 03 turbo w/billet wheel, AFE stage2, 5"diamond eye, BPD egr cooler & "NEW" external oil cooler, BPD 48v FICM, BPD water pump, BPD aluminum radiator, 6.4 banjo's, blue spring, HFCM e-z drain, riff raff boots, gearhead srl tune , PHP FICM tune, sct livewire 5015, updated stc, updated stand pipes & dummy plugs, updated oil feed & drain, Zerex ELC coolant, Pro Comp 6" lift, 325/70/17 Toyo open country at
sprksonu is offline
post #2 of 6 Old 07-21-2013, 09:39 PM
JSchuricht's Avatar
I think your charge indicator is broken. It's still showing black where the cord is plugged in. It should turn green.
JSchuricht is offline
post #3 of 6 Old 07-21-2013, 09:48 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
that's freakin hilarious bud
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #4 of 6 Old 07-21-2013, 11:31 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
PRICELESS!!!
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #5 of 6 Old 07-22-2013, 03:40 AM
usnavyad's Avatar
Feedback Score: 3 reviews
That's awesome lmao
04 harley davidson f-250 arp headstuds oem gaskets,sb intake,edge cts egt probe,sct sf3 idp tuned/ php tuned,blue spring,zerex coolant swap,mbrp 5 inch xdp 6 inch tip,sinister egr cooler,new oem oil cooler,atlas 40 ficm,Painted cac tubes 7.3l wire loom,Diesel site coolant filter
GPDA's other shawn
usnavyad is offline
post #6 of 6 Old 07-22-2013, 05:36 AM
6.0newb!'s Avatar
Quoted: 14 Post(s)
Hahaha "pure genious Lloyd" (dumb and dummer)
06 f-250 ECSB xlt fx4, MBRP 4" cool duals, AFE stage 2 intake, BPD water pump, BPD egr cooler, stc update, stand pipes, dummy plugs, blue spring, late 04 up pipe, wicked wheel 2, PMM coolant filter, Riff Raff ic boots, t6-5w40, Rotella elc, leveling kit with 350 blocks, Pro Comp pro runner shocks, full Powerstop z36 brakes, PHP ficm tuner, insight cts w/egt, SCT x3 with canned tunes...... for now
6.0newb! is offline
