Looking for Advice - Ford Powerstroke Diesel Forum
post #1 of 22 Old 10-13-2013, 02:55 AM Thread Starter
MSTR-P's Avatar
Looking for Advice
Alright gents...my '03 7.3 has an exhaust leak coming from the passenger side up-pipe. The leak is where the up-pipe bolts to the exhaust manifold...bolt snapped in the middle and I can't get either end out. So, to go along with the new bellowed up-pipes, I am going to order some new manifolds and just replace the whole thing. As you can imagine, there is a crazy amount of corrosion on the manifolds...to the point where I might have to cut the heads off, pull the manifolds, and take the bolts out with vise grips. My question...have any of you done this before, and if so, is there an easier way, or anything I should watch out for?
Thanks,
Mike
'03 7.3 - Stock!
MSTR-P is offline
post #2 of 22 Old 10-13-2013, 04:10 AM
MrOneEyedBoh's Avatar
Quoted: 13 Post(s)
Feedback Score: 11 reviews
This sounds like a wrenching day is coming up!!
MrOneEyedBoh is offline
post #3 of 22 Old 10-13-2013, 11:14 AM Thread Starter
MSTR-P's Avatar
Honestly, I will take all the help I can get. I am not a mechanic but have done basic stuff like changed the starter, tensioner pulley, serpentine belts, exhaust, brake lines...things like that. In another week or so, I am going to try my hand at doing a lift swap and then, with the added room under the truck, try replacing the manifolds and up pipe.
'03 7.3 - Stock!
MSTR-P is offline
post #4 of 22 Old 10-25-2013, 06:04 AM
importedaze300's Avatar
Some of us are or were mechanics as far as the lift easy I have done a 2wd to 4x4 swap so if u need help I will be more then willing to give a hand
6637 filter
5" exhaust
bts valve body
gtp38r
no ebvp pedestal and exhaust outlet
oil feed line cross over
ts 6 position chip
6" lift
20" fuel wheels on 35s
2x4 to 4x4 conversion
2001 supercab 4x4 manual no mods
importedaze300 is offline
post #5 of 22 Old 10-25-2013, 06:28 AM
Quoted: 3 Post(s)
I know a ton about suspension, I can definitely help with that
11 F250 CCSB King Ranch
Tyrant tunes, No Limit Stage 2, No Limit Block Off, 5" exhaust, CTS
2.5" Carli Commuter, 4.5" PMF block, 37x12.5R20 Toyo RTs, Stock wheels
01 Ex 7.3l Limited
Swamps tunes, 6637, 4" exhaust, 6.0 trans cooler, Hellwig rear swaybar, CTS
06 headlights
bigred3297 is offline
post #6 of 22 Old 10-25-2013, 06:42 AM
I like your setup even more so after seeing bit in person even with the six inch on mine it still looked like a midget next to yours
6637 filter
5" exhaust
bts valve body
gtp38r
ts 6 position chip
6" lift
post #7 of 22 Old 10-26-2013, 03:07 PM
Quoted: 3 Post(s)
Thanks. It's hard to grasp how big it is until you see it in person. Or park your truck next to it lol
01 Ex 7.3l Limited
06 headlights
post #8 of 22 Old 10-27-2013, 03:25 AM Thread Starter
MSTR-P's Avatar
So...the swap went well. Took a couple of days, but I got her finished. I didn't get home until late last night and am work today, but will post pics of it soon. I put on a 8 1/2 inch pro-comp with 20x12 Weld Dune 8's with some 38 Toyo MT's that are going to need changed sooner rather than later. All in all, very satisfied with the new look and she drives/rides nice and smooth.
'03 7.3 - Stock!
MSTR-P is offline
post #9 of 22 Old 10-27-2013, 04:17 AM
Quoted: 13 Post(s)
You're not worried about getting hit with inspection tickets? It seemed like for a while there the police were crazy about it. Then when I had my lifted jeep about 2 years ago, they never even looked. I wonder if its going to become hot again and then it will happen all over. I mean I can see if you're a little bit over the lift laws but when you're jacked way up, its just asking for trouble.
Whats your bumper height at the lowest point?
post #10 of 22 Old 10-27-2013, 04:52 AM
Whats your bumper height at the lowest point?[/QUOTE]
Mine is 27 the legal limit for trucks is 28 now there are no suspension laws or tire size restriction as long as the frame is kept within limit now the state police are the ones who mainly enforce this if u wanna look it up the Maryland code it is covered in the MCT-22
6637 filter
5" exhaust
bts valve body
gtp38r
ts 6 position chip
6" lift
