any one have Blockcheck test/ head gasket tester - Ford Powerstroke Diesel Forum
Old 06-20-2012, 05:20 PM
does anyone have that block check tester where you have fluid that changed color above the coolant overflow tank around carrol or fredrick county? id like to test mine i have high pressure in the coolant system but dont puke or over heat. if anyone has it id give you a couple buck if you would test mine since in the kit you get it suppost to be plenty of fluid for multiply checks.
