2008 4" Inlet with 3.5" Dual Tailpipe DPF Exhaust Kit - Ford Powerstroke Diesel Forum
Magnaflow Performance Exhaust Magnaflow
Old 01-22-2008, 01:08 PM
MagnaFlow is pleased to announce 4” Inlet w/ 3.5” Dual DPF Exhaust Kit. For specs on the system’s configuration, pipe size, layout and tip configuration, see pictures below:
The new cat back system for this application has been dyno verified to make 24 hp and 36 lbs. ft of torque. It features full mandrel bends (no compression bends, like those done at muffler shops) for maximum flow and a straight through, wide open muffler with NO baffles, NO chambers and NO restrictions. The system installs with simple hand tools and in most cases, can be installed by the average do-it-yourselfer in 30-60 minutes.
For more info:
MagnaFlow Performance Exhaust - For Diesel Trucks
Installation Instructions:
http://www.magnaflow.com/07techtips/pdfs/16987.pdf
The system is backed by the best warranty in the business (LIFETIME):
For a Dealer in your area:
MagnaFlow Performance Exhaust - Dealer Locator
To buy from one of our Nationwide Retailers:
MagnaFlow Performance Exhaust - Buy Online
Old 03-22-2008, 06:11 PM
why cant this kit be used on an 03-07 6.0 Liter??
Old 03-25-2008, 08:39 AM
This kit is only designed for the DPF on the new 6.4L Diesels
Old 03-25-2008, 05:01 PM
i like the look of the TWO side-by-side pipes 4" into dual side by side 3.5's
I would think if you guys offered a system like this for a 6.0 you'd sell alot of them
Old 03-26-2008, 07:43 AM
To be completely honest with you. You are the first person to ever ask this question. Yeah it would look cool. But not alot of people are showing interest in this set up for the older model trucks
Old 03-26-2008, 03:30 PM
what is in the kit that makes it not usable on an 03-07 truck.
I would think the tail pipes ove the axle would fit.wouldnt they.
Could i buy the tail pipes and thr Y and bolt it in??
Iam gonna put a post in the 6.0 Forum and see how many guys would want the side by side exhaust
Old 03-27-2008, 07:06 AM
Email Me and I will send you the cad drawing and you will be able to see why it wouldnt work. We dont sell components. All of our kits are built per box.
Old 09-12-2010, 11:16 AM
id by one! 5 inch..id buy it
Old 04-20-2011, 07:43 AM
I'm a little confused. Does this kit delete the DPF? And does the dual pipes run parallel to each other and exit on the same side or is it just they way they're configured for the picture?
